Last Post: logan
2004 Bourget Retro
Posted On: 08-10-2020
Posted On: 08-09-2020
New Forum Member
  #151 (permalink)
Old 04-21-2007, 04:51 PM
Stynie's Avatar
Here's a pic of the vent I used. Cost was less than $20.
  #152 (permalink)
Old 04-21-2007, 05:47 PM
BOSS's Avatar
cool..i think i have a filter like that in the garage somewhere...
just have to find some hose and a fitting i suppose.
  #153 (permalink)
Old 03-20-2008, 08:54 AM
Bike Year, Make, Engine: 2005 BMS Custom
leaking 113
I have a 113 ultima which has little to no miles and is leaking between the spacer and the output shaft.
Is the spacer supposed to be loose? I can move mine about 1/8" in and out.
Mine leaks while sitting still and not running. I dont think it leaks when heated up but more when cools down. I have the open primary off and cleaned everything and found oil coming through between the spacer and the shaft so I am pretty sure thats it.
What kind of job is it to take the seal, spacer out to fix the problem? Will the o-ring behind the spacer fix my problem?
  #154 (permalink)
Old 03-20-2008, 12:22 PM
Some guys put some sealer between the spacer and the shaft.
  #155 (permalink)
Old 03-20-2008, 01:29 PM
PART OF THE CREW FUCK OFF
i know i know nothing ...but after a while that filter is going to clog with road grime and get black and oily and not breath and make a mess....get that hose a foot long and run it along the frame and to the ground with no filter on end ..open...and please dont say it will suck in
  #156 (permalink)
Old 03-20-2008, 01:54 PM
bob o's Avatar
Bike Year, Make, Engine: 06 CFL 127 EL BRUTO
I have a Ultima 127 and was told by SMW to put a very small amount of silicone on the crank shaft between the shaft and the spacer. Once I did no more leak. Just dont use to much or you will have silicone in the oil system also let it dry before you run it. you will need to fill in the splines of the gear......
  #157 (permalink)
Old 02-26-2012, 02:37 AM
Stynie i have a 127 that leaked oil at the seal, put a new one in and it still leaked, pulled it all apart agian and under the bearing boss is a hair line fracture. motors only 30 hours old, 2000 miles. good luck mate.
  #158 (permalink)
Old 02-06-2013, 06:45 AM
Bike Year, Make, Engine: 08 ultima chopper
I have a ultima 113 with a 3" bdl open primary I am replacing the seals on. my manual came with this page http://www.ultimaproducts.com/EPAEngineManual.pdf see page 14
http://www.ultimaproducts.com/CSEngineManual.pdf see page 11
  #159 (permalink)
Old 09-28-2017, 06:05 PM
Hello all. I have had the same problem. I've tried every suggesting here and then some and cannot get the seal to stop leaking. I'm leaning towards a breather issue. Any suggestions on how to go about trouble shooting this?
