Turn signals
Last Post: gduncan
Posted On: 07-09-2020
Posted On: 07-08-2020
Identify Frame *Help
Last Post: gduncan
Posted On: 07-06-2020
  #136 (permalink)
Old 04-09-2007, 05:57 PM
BOSS's Avatar
Originally Posted by Stynie
I asked cause I've been thinking. One of the times I changed the seal, I took it out for an easy ride and it didn't leak until the next when I had done a few holeshots. So maybe it is a pressure issue as some have mentioned.....maybe.
could be...but a 127" engine and much good if i cant use it!!!
  #137 (permalink)
Old 04-09-2007, 06:01 PM
Stynie's Avatar
Someone mentioned that EBOC or whatever he called it in an earlier post for venting the case. Maybe you should give Ultima a call.
  #138 (permalink)
Old 04-09-2007, 06:04 PM
Stynie's Avatar
Originally Posted by dave19
I talked to Ultima and they have a product called an EBOC. It is a lower end breather. I installed one on my 127" but not enough miles on it yet to tell if it works. I figured it can't hurt. Sounds like you have a pressure problem if it leaks after a while once it builds up pressure.
this thing
  #139 (permalink)
Old 04-10-2007, 05:31 AM
BOSS's Avatar
bump for the morning.....
picked up some o-rings and gonna grab a couple new seals and sleeve today if its in stock......any thoughts on putting 2 seals in...is that possible ??
  #140 (permalink)
Old 04-13-2007, 03:58 PM
Stynie's Avatar
Finally got to test my bike out today, and it seems I have finally stopped the leak . I used an o-ring behind the spacer and vented the case. I'm really not sure what fixed it, but right now I couldn't really give a shit...IT'S FIXED!! For the vent, I pulled out the plug next to the oil pump and connected a 4" piece of 5/16" hose curved straight up to a small breather which is just zip tied to the closest oil line. Picked up the fitting at Lowe's for the connection. There does not appear to be any oil visible at the breather either, and I did run it pretty hard too. Boss I hope this helps you, if you haven't fixed yours yet. Thanks to all for the suggestions. Eric
  #141 (permalink)
Old 04-13-2007, 05:04 PM
Stynie's Avatar
Check that. Still leaking. Not as big of a puddle as before and took a while to start dripping. Going to tear it down right now.
  #142 (permalink)
Old 04-13-2007, 05:27 PM
Stynie's Avatar
Found the problem. The bottom most stator bolt is leaking. Must be drilled too deep. Previous times I have used permatex on the bolts, but not this time(don't ask). Judging by the amount of oil and how long it took to drip this time, I think this time was a different issue than last few times(fingers crossed). Anyone know what would be the best sealant for this problem?
  #143 (permalink)
Old 04-13-2007, 05:28 PM
Dude!!!!!!!!!!!!
I told you about that!!!!!!!!!!!!!!!!!! LOL LOL
Any thread sealer will do.
  #144 (permalink)
Old 04-13-2007, 06:54 PM
Stynie's Avatar
After checking further........is it possible it was residual oil in the stator that came out of the windings after the engine was hot? Or maybe not. I forced air into the hole again, but heard nothing.
  #145 (permalink)
Old 04-13-2007, 09:07 PM
Stynie's Avatar
  #146 (permalink)
Old 04-14-2007, 04:24 PM
Stynie's Avatar
Cleaned the stator, put thread sealer on the stator screws. Took it out and rode it hard and it does not leak NO MORE!!!!
  #147 (permalink)
Old 04-17-2007, 09:03 PM
skylarbluepuppy's Avatar
Bike Year, Make, Engine: 06 pitbull
good deal i hate leaks
  #148 (permalink)
Old 04-17-2007, 09:47 PM
juicer's Avatar
Bike Year, Make, Engine: '02 Confederate Hellcat,113S&S
Thats great man, send it!!
If it ain't broke fix it 'till it is
  #149 (permalink)
Old 04-18-2007, 12:25 AM
PART OF THE CREW FUCK OFF
i have to take a leak after reading this
  #150 (permalink)
Old 04-20-2007, 05:27 AM
BOSS's Avatar
mine started leaking again after having it out for a few rides and pounding on it last night....going to check my stator bolts as well now i guess.....and maybe try that vent idea......worst case....switch it to closed primary i guess.
now oil is dripping of the S&S carb cover onto the pipes as well....never had that before!
