Last Post: John Spartan
Last Post: SKT
WCC coffin air cleaner
Posted On: 01-13-2018
Looking for Talon lowers
Old 09-20-2006, 07:07 AM
choppedcadillac's Avatar
Bike Year, Make, Engine: 04 BigDog, 69 Shovel, 78 Superglide
twin cam ignition wiring for chopper
Im building a twin cam powered stretched chopper. Id like some advise on wiring the ignition. Anyone have a schematic or diagram? Twn cams are new to me. Appreciate it ..thanks
Old 09-20-2006, 08:11 AM
Cyclone V-Twins's Avatar
Bike Year, Make, Engine: 2009 bobber HD/S&S
What ignition are you going to run. Stock type ignition requires a lot of sensors and wiring. I built a Twin Cam B chopper this spring and used a Thunder heart ignition which required use of only the crank position sensor. I just followed the instructions that were included so it was pretty straight forward. The "module"needs to be mounted somewhere so I boxed out the front of the rear fender under the seat to make a place to mount it. 3,000 miles now and so far so good.
Old 09-20-2006, 08:20 AM
Bike Year, Make, Engine: 100" Chopper, '56 FLE PAN
here's one for you
Old 09-20-2006, 08:26 AM
Bike Year, Make, Engine: carolina custom chop proj
if your using an "A" engine go grab a 2000 up dyna manual, if your using a "B" engine get a softail manual. depending on the year your looking at wiring for a MAP sensor, cam sensor, crank sensor (depends on year) and a few other odds and ends.
Old 09-20-2006, 09:02 AM
twn cam ignition
i'm using an A motor with the adapter for the evo mounting in soft tail frame. i appreciate the feedback from all...thanks
Old 09-20-2006, 09:26 AM
I used a S&S setup on the last twin cam bike we built. pt#55-1012 harness with thier ist ignition drag pt#2102-0079. It uses all the HD sensors crank position, cam position etc. and they sell a harness so it just plugs together. Vulcan also makes a cam cover that accepts an evo style ignition but its cheaper to go the S&S route.
Old 09-20-2006, 10:19 AM
Bike Year, Make, Engine: 2002 HD FXSTI, 2006 WCC CFL
I am planning on using the Thunderheart ASM-5012 on my TC88 powered CFL. It seems to be most simple/economical way to go. http://www.thunder-heart.com/IgnitionCoils.html
