cfl single downtube chopper
Posted On: 01-15-2020
Vertical stretch
Last Post: riverratba
Posted On: 01-13-2020
Last Post: John Spartan
Old 05-01-2006, 07:22 PM
Bike Year, Make, Engine: 1976 FLH,1340
76 Shovelhead FLH
Anyone got a diagrahm for the start circuit on 76 FLH? This has the relay under the battery box and the solenoid mounts parallel to the primary.
Old 05-02-2006, 02:15 AM
Sure do, but I don't know how to post it... Maybe this'll help:
On the starter relay, 1((tan) goes to battery positive and the ignition switch(1 & 3), 2(Green) goes to the trigger terminal on the solenoid, and 3(black) goes to a terminal in the bullnose that goes to the starter switch on the handlebar - the other side of the starter switch goes to the kill switch center terminal, which also goes(white) to the neutral light and the ignition coil... The end terminal of the kill switch(Grey) goes to a terminal in the bullnose, then on to the ignition circuit breaker - the other side of that breaker goes to the ignition switch(5&6)...
The starter relay also shows a black wire that's grounded to a trans stud...
Take it one circuit at a time, and you should be OK...
- georgestrings
Old 05-02-2006, 11:48 PM
Bike Year, Make, Engine: 74 XLCH, 89 FLSTC, 04 Custom
try this
http://smokeriders.com/diagrams/inde...976_FL_FLH.gif
Old 05-02-2006, 11:51 PM
Thanks Man. But how do I know which terminal on the relay is what?
Old 05-03-2006, 06:30 AM
Are the posts marked?
