Chopper styled hot rod trike
Last Post: DeathBySnuSnu
70s Style Britt Choppa
New guy in FL
Looking for Talon lowers
Last Post: 2up2out200
Posted On: 05-22-2018
WCC coffin air cleaner
Old 10-17-2005, 09:54 AM
230 tire, rigid frame, 13.5" space
I have a rolling thunder frame for a 230 rear tire and 1.5" belt setup. There is 13.5" of open space between the rear of the frame where the tire goes. I'm most likely gonna mount the tire on a 7" rim.
I would prefer to run an EXILE sprotor brake set-up. Is the 13.5" of space I have too much to go to just a sprotor brake? Will the other side look too "empty"?
Old 10-17-2005, 10:28 AM
Hanoverfiste's Avatar
Bike Year, Make, Engine: 1999 Sporty Custom 1200
thats alot of space. I am running a 240 on a 7" rim, with 1.1/8"belt on the right hand side , and My brake side looks empty...
To the road less travelled.......
Old 10-17-2005, 10:30 AM
forgot to mention I have 12.5" between my swingarm rails..
Old 10-17-2005, 10:35 AM
yeah maybe ill just go with the belt drive. i wanted to use the sprotor, but i guess i won't now.
any more opinions??
Old 10-17-2005, 10:47 AM
EYECANDYCUSTOMS's Avatar
Bike Year, Make, Engine: Chopper
240/16 metzler
Old 10-17-2005, 10:54 AM
Originally posted by EYECANDYCUSTOMS
240/16 metzler
are you saying thats the set-up i should go with???
im sure you meant 240/40-R18 metzeler. I think im gonna go with that tire and now use the sprotor. I like the lower profile look of the 240 anyway.
Thanks alot eyecandycustoms!
im now seeing that they do make a 240/50- 16.
decisions, decisions, lol
Old 10-17-2005, 11:56 AM
i have the 240/50 16. trying to find a 8.5" wide wire wheel for it... using a 7"wide 16 wheel right now...
Old 10-17-2005, 12:06 PM
metzeler only recommends 7-8" rims for that tire. Im thinking of going with the 240/50-16 with the 8" rim. From the metzeler website is looks like that tire will be about 9.5 inches across when i mount it. I hope that tire takes up the right amount of space with the 13.5" width i have to work with without having to use a giant spacer on the right side.
I hope with this tire i can mount it with the exile sprotor and have a super clean look.
any more ideas or suggestions???
Old 10-17-2005, 08:57 PM
240/16 metzler
thanks dude
_____~~
Old 10-20-2005, 06:12 AM
Black bike can make any size wheel you want for that 240/16 metzler. There shouldnt be any reason you cant run the exile sprotor setup, but i would check ito killer choppers sprotor setup. They use a 4 piston brake rather than exiles 2-piston setup. Exiles is a little week.
Old 10-21-2005, 07:34 AM
yeah, the killerchopper sprotor brake looks real nice. I just called but they said it will be 2 weeks for shipment I'd like to get one sooner.
Old 10-22-2005, 07:25 PM
Bike Year, Make, Engine: 100" Chopper, '56 FLE PAN
I have 13 5/8" between the wishbones for my 280 setup.
Scott
