El Diablo prices
Last Post: JJ500
Power motorsports
Chain length
Posted On: 07-30-2020
2004 Bourget Retro
Last Post: DRZ
Old 10-12-2005, 07:43 PM
Bike Year, Make, Engine: many
fifth transmission bolt----cut off?
I have an rc component softail frame with a 1 1/4 inch offset on the trans. The offset plate has four holes that line up with the four bolts on the trans, but there is one more bolt that bottoms out on the right side shock. Does this need to be cut off? I can't see any other alternative but thought I would ask the pro's before cuttin'.
Old 10-12-2005, 07:58 PM
gypsy chopper's Avatar
i always put a mount there, the type depends on the shocks
Old 10-13-2005, 12:34 AM
Magchange's Avatar
Bike Year, Make, Engine: BBC Venom Chop,107ci
I cut mine off ,but I also have another bracket that goes from two of the lower tranny cover cap screws to a welded on tab on the frame, whatever you do don't try to unscrew or pull this stud use a cut off wheel.
Old 10-13-2005, 03:47 AM
fireforeffect's Avatar
Would that be because it's threaded all the way through and if you take it out the tranny fluid will drain out? I love discovery learning. That's what mine did.
I cut my mounting tab off the frame when I shifted my tranny to the left, but did reinforce the tranny to the motor w/ a Carlini torque arm to keep it from having any flex w/out the 5th mounting bolt.
Old 10-13-2005, 05:11 AM
King Mouse's Avatar
Bike Year, Make, Engine: Handmade Sunset
That stud does go all the way through. I made a mount similar to the baker mount and bolted it to the frame.
Old 10-13-2005, 06:02 AM
Puzzled's Avatar
Bike Year, Make, Engine: 2003 Custom Rigid Springer Chopper, 124"
On one bike I cut it off completely (mount, stud the whole thing)and on the other I used a bolt (short one) and ran it up into the trans and on the third one I installed the nuts and cut the remaining threads off.
03 Custom Rigid Springer Chopper, 124" TP, Jims 6spd, 10up 7 out 47* rake 2 back. 01 HD Screamin' Eagle Road Glide, Baker DD6, Pioneer AVIC N2, RC Comps 21"/18". 00 Suzuki GSX 1300R Hayabusa, 10" over 250 arm, Turbo w/water injection. 97/00 "Budget Build" TC88 Softail, 20" Apes, hand shift, left side exhaust.
http://www.motorcycleturntabledisplay.com
Old 10-13-2005, 06:26 AM
crackbaby's Avatar
Bike Year, Make, Engine: 01 FLHTCUI
Hey dair to all yous clubchopper folks, dair be some good suggestions here from all yous smart folks, but de main ting you's gots to keep in mind. Yes de 5th mount stud is a "through" hole, and will leak if removed. You do need to re inforce the back of the transmission, you can re locate the 5th mount, possible change some of the hardware out, or like Da Gypsy man said sometimes de shocks can be part of de issue. Always does whats best fer ya, but don't cut any corners when it comes to being smart and being safe!............
...........nows while yous be ponderin dat, I'll be gittin ready fer de next round of as de bong turns!
My life was completely changed, the day I let Jesus in. Transformation in progress
Old 10-13-2005, 06:34 AM
heres an easy way if you got an integral tranny plate
Old 10-13-2005, 06:41 AM
Puzzled's Avatar
Old 10-13-2005, 07:03 AM
Hotch's Avatar
Bike Year, Make, Engine: 05 Venom S&S 107
Ditto. For BBC bikes they say LSD cut off bolt and use bracket. RSD, use the 5th bolt
Old 10-13-2005, 01:45 PM
King Mouse's Avatar
Gypsy,
Nice welds on that frame.
Old 10-13-2005, 02:58 PM
Yeah, they're just a little cleaner than those shown in the other thread, eh?
Old 10-13-2005, 03:04 PM
Maybeeeeeeee
Thanks for all of the ideas. Maybe I could weld a bracket onto the offset trans plate. If it does not clear the shocks----maybe a smaller pair of shocks would work.
Old 10-13-2005, 03:54 PM
to be honest, that is a frame built by american racing. sold under the name covington cycle city.
but since my welding is on the line here
http://www.clubchopper.com/photopost...sort=1&cat=500
and my metalcrafty aptitude is being subjected to a test....
http://www.clubchopper.com/photopost...cat=500&page=6
i do alright, i have built enough fenders, dashes, and general bike parts at milwaukee iron to learn a thing or two about tig welding...so dont worry bout me...jfwy
Old 10-13-2005, 04:43 PM
Bike Year, Make, Engine: R.U.B. "Chrome" chopper R/T 110
Come on Gypsee,
That is just Photoshop. You drew in all the welds and metalworking stuff. You can't fool us.
