Starter torque dpecs
Hunting an AIH Wiring Diagram
Last Post: Bostonjake01
Posted On: 02-15-2020
Posted On: 02-14-2020
Old 08-26-2005, 10:18 AM
PsychoJester's Avatar
Bike Year, Make, Engine: Hardcore 2
I do lots of polishing at work.
If it's aluminum or Stainless steel, you can polish it until it has a mirror finish. But it will take a lot of work and it will make a big ass mess.
If it is really scratched or ruff I would start with scotch brite (usually white). Then get a buffing wheel either for your bench grinder, or you can get one that fits your die grinder. Then use jewelers rouge. I use red rouge with most projects. But white is supposed to be for stainless steel. Polish until you get the finish you like, it can polish as shiney as chrome. Although I don't think you can use this method on chrome plating (because it is PLATING which is very thin).
All items can be bought at Home Depot or Lowes.
PsychoJester
rwb's Avatar
rwb rwb is offline
Bike Year, Make, Engine: 05' PP100 Custom
Originally posted by sickchoppers
black bandana 2 bucks then grab a few beers get hammered fire the bike after drunk pull the throttle real hard listen to the sound then tell me if a few scratches really bother you
if they look close at the scratches slam there fuckin head into yer trees till they bleed
come on guys!
SIck is right, and he should know, HE is strictly HARDCORE !!
Get some Garnet sandpaper, say about 80 grit and wrap your hands around the tube and have at it, I'd say 20 minutes each side should do it, kinda like its your pud !
Now you will have that "industrial" scratched look and both sides will match. Kinda like the "exile" look.
Also, do like SIckchoppers does, when your done riding, just get off the bike and throw it down like a bicycle when you were a kid.....who need a kickstand !!!!!!
Stick with Sick, He will school you
Douchebag says what.........
Old 08-26-2005, 12:28 PM
CENJIM's Avatar
As Gypsy said, get a magnet and see if it's aluminum or steel.
Very simple to do. Then you know who's right.
Old 08-26-2005, 12:40 PM
gypsy chopper's Avatar
Originally posted by Eric_107
Hey einstein, I called 3 different shops- 1 HD, 1 BDM, 1 independent...they all said the same thing= ALUMINUM! So, I guess you fuckin know-it-alls are NOT as wise as you think!
thats a pretty good cross section of the industry, nice gathering of experts.
ok...fork tubes are aluminum, i was lying the whole time, guess this time i got caught!
what they didnt tell you is that some of the less expensive ones are made out of PVC...then painted with chrome spray paint, but you can usually tell those from the good ones when the paint starts fading. some of the mexican tubes are actually a mixture of straw and mud, called adobe...those really arent worth owning for the street tho, mostly just dirtbike applications(and show bike type stuff).
ive been telling folks that(bout the steel) for years, never been caught like that before(the magnet thing is just a parlour trick)...sometimes i go farther and say expensive forks are covered in titanium nitride, but thats when im really tellin fish stories!
sorry
Old 08-26-2005, 12:58 PM
Bike Year, Make, Engine: 2004, Big Dog Chopper, 107 Cu. In. S&S
sorry [/b]
Holly Crap - that's some funny shit there.
Old 08-26-2005, 01:03 PM
as far as taking fine scratches, i called the h-d shop, bdm, and an independant shop and they all concurred...rub it briskly with a red brick, but put shaving cream or a soap lather on it so the abrasives dont go away till your done.
cover the area so you cant see the fork tube anymore, and go to it with the brick and a little elbow grease, take a look after about 5 minutes...they all said you may have to use a degreaser to clean the mess
hope that helps!
Old 08-26-2005, 01:43 PM
That's some funny shit Gypsy
I've seen some of the asian ones made of bamboo
and some african ones made of bone both wrapped with aluminum foil. Be careful where your parts are mede.
Old 08-26-2005, 02:08 PM
Will E Ryder's Avatar
Bike Year, Make, Engine: 72 Ironhead rigid
Too funny Gypsy
I can't believe it takes 3 pages of posts to figure this out. Gypsy, you would probably know this: Have they EVER made telescopic fork tubes out of anything else? I know the coating/plating might vary but I've never heard of tubes being made from anything other than steel. Unless I'm mistaken? I'm just trying to figure out why anyone would suggest otherwise.
Old 08-26-2005, 02:27 PM
i'm sure somewhere down the line stainless most likely got tried.
i have actually seen them made out of stacked tomatoes, and back years ago, if i remember right, easyrider ran one made out of compressed fish eyes. i myself have experimented with stringing shipping popcorn on a welding rod, but found it slightly squirrely in the hard corners!
thanks for the enquiry,
duh
Old 08-26-2005, 02:31 PM
Ralph D's Avatar
'03 AIH/113" S&S
Bike Year, Make, Engine: 2003 AIH 113"
Can a bike run with scratched fork tubes? There is no way that can be safe!
Old 08-26-2005, 02:57 PM
freeway's Avatar
true to the cause
All I tried to do was give a guy some help, he obviously does`nt know his onions, or he`d know the difference between fork tubes and fork legs, and chrome and alloy, should probably stick to plastic you can`t mistake that!, or can you?
Old 08-26-2005, 04:58 PM
just fuggin with you eric 107 i think it is a miscommunication over terms. the part in your box is the tube, the aluminum part at the bottom is the slider
Old 08-26-2005, 06:59 PM
fireforeffect's Avatar
Yeah, those african ones use the tinfoil to distort the outerspace radio waves, so the aliens can't determine what the tubes are made out of. Everyone knows that all they want to do is copy our stuff.
Old 08-26-2005, 09:16 PM
Nick Wild's Avatar
Bike Year, Make, Engine: 05 BD chop 117" s&s
duh
and i thought you knew your shit...the best material to build front forks is 3/4" Galvanized Electrical Conduit
POSE TILL YA DROP .......BITCH
Old 08-26-2005, 09:25 PM
Ogur's Avatar
Bike Year, Make, Engine: "05 Death Trap
Gypsy, you kill me man. Have you made a decision on the little project I have.
I pledge allegiance to my EVO, built in the United States of America!
And on the lever, by which it stands.
One title, under guard, hardly invisible.
With loud pipes and irritation for all.
~redrigid~
