Oil Lines
Last Post: Maustarman
Posted On: 08-14-2019
Bars upside down
Posted On: 08-12-2019
Posted On: 08-10-2019
Last Post: donald branscom
Posted On: 08-09-2019
Project Blast!
Posted On: 08-08-2019
Old 11-24-2003, 12:34 PM
Dude's Avatar
Bike Year, Make, Engine: Prostreet RSD 280 TP121
PM Drive side brakes
Reading the PM website on drive side rear brakes - you need to weld on the tabs and use PM pulleys and wheels. From looking at all the bikes in magazines that use drive side they all use PM pulleys and wheels. My question is how does BBC use PM drive side conversion with Pro-One wheels and pulleys? When I talked to IHC they also use PM dive side with EVO wheels and pulleys. Hows it done??
Old 11-24-2003, 12:40 PM
I think PM just says that so you think you have to buy their wheels and pulleys. Actually, and I'm not 100% positive on this, but wouldn't any type of motorcycle wheel/pulley/rotor work because all things considered they're basically the same design?
Old 11-24-2003, 12:51 PM
Bike Year, Make, Engine: 2003 Hotmatch custom cycles
I am using Pm drive side brakes, with PM wheels but I did a project a few months back using RC Components wheels and PM Drive side braking.
No problem just have to space things and line things up to suit it, where as with the PM it is pretty much weld the tabs on and every thing else falls into place.
Old 11-26-2003, 08:07 AM
Bike Year, Make, Engine: one of a kinds
I am using a PM driveside on my current project. I have PM wheels also, but, I dont see any reason you cant use any wheel as long as it is at least 18" in diameter. Also you have to make sure the offset is deep enough since the caliper is actually inside the diameter of the wheel. The rotor and pulley bolt on the the pulley side flange as one unit. PM hubs do have the correct spacing and when used together is a very clean setup!
Unless there is a wheel that you absolutely cant live without I would recommend using PM wheels. I believe it will save you a headache.
Old 11-26-2003, 02:42 PM
Gearhead's Avatar
Bike Year, Make, Engine: > 1
They can be used with the left side drive wheels and pulley you mention. Spacing can be adjusted. Some minor milling of the bracket might be necessary for proper snug fitment. And the tabs that come with the PM kit can be modified as needed to fit the swingarm style and carry the bracket properly. My tabs welded on this week for a PM left side drive kit.
Old 11-26-2003, 07:54 PM
RippoDippo's Avatar
Well if my R wheel would show up I'd like to figure it out and get it over with
Ya how do you hang the Caliper behide the Pully
Old 11-27-2003, 12:55 PM
PM makes the bracket to hang your caliper. It comes with weld on tabs for the swingarm. (You can only use a PM caliper on it. ) Got to have a spacer also to go between your pully and rotor.
Old 11-28-2003, 09:42 PM
RippoDippo's Avatar
Bin looking And I figure this is the jem I need.
Part # 1284-0074-CH
Ok this is the Ad
Caliper and Bracket (with tabs) $699.95
Anouther listing just below.
Caliper and Bracket (without tabs) $699.95 ((What did i miss?))
And then ;
Must use PM Disc, Pulley and Wheel!
Good thing is they do offer Black Anodized at same price as Chrome
But Sprocket is Chrome So Chrome Here!
