Last Post: Slik_one69
front Brake hose
Posted On: 02-18-2018
My Budget Bagger Build
Last Post: thefreeauction
Posted On: 02-17-2018
Posted On: 02-14-2018
Old 05-07-2005, 08:34 PM
Bike Year, Make, Engine: Redneck
Question Oil Change Redneck w/Revtech 110
Put the first 50 miles on the Redneck Rocket today. Pretty sweet. Anyway I'm doing the 1st oil change & I pulled just under 2 quarts out of the oil tank. I initially put in 3. I know my brother has to drain his motor on his Yamaha, but I don't on my Harley. Plus, I don't see a seperate motor plug on my Revtech 110. How is the oil swap handled for my combo?
Thanks.
Old 05-07-2005, 08:36 PM
gypsy chopper's Avatar
fill the filter up and dump two qts in the oil tank
Old 05-08-2005, 10:33 AM
Seems crazy ...... I must be overlooking an engine plug. who else has a 110?
Old 05-09-2005, 05:37 AM
most motors dont have engine plugs...maybe that does i dont know...it only holds a few ounces in the block...i wouldnt worry about it
Old 05-09-2005, 06:38 AM
Bike Year, Make, Engine: 1987 HD FXRS-SP 80"
RevTech probably did the same exact thing that Harley does... It's a "dry-sump" system. Meaning that there is little or no oil held in the engine. Unlike your brother's Yamaha with the wet-sump system. The oil tank is where the oil is held on your Vtwin. The Yamaha holds it in the cases (sorta like a regular car)...
What ever you get out of the tank and oil filter is pretty much it.
Ride it like you stole it...
Old 05-09-2005, 07:20 AM
Fuelie's Avatar
Bike Year, Make, Engine: FXE "91" Shovel, Fuel drag bike
Dear snkebyt,
One thing you may not be aware of is that the RevTech Gen III engines, both 110, and 4X4 100 don't use a breather gear like old evo engines. The RevTech is a bit of a hybrid in some manors. the engine even though it is a "dry sump" style engine can hold more oil in the crankcase than a standard Harley. Now at the bottom of the sump plate, there are two set screws facing outward. They are directly connected to the oil sump and system. You may pull those and find a fair amount of oil. Now again with out a breather, and over time engines can leak past the check ball in the oil pump. This is not anything to really worry about, but I will tell you something else. Call the guys at Custom Chrome and ask them about the "oil system performace update" This is a "Free" update they provide. It alters the oil system in a way that further reduces the oil in the crankcase. The plus of this is reduced engine temp, and a slight increase in HP. Not a bad gig, and I have peformed this myself for people, and one it's simple, and two it fricken works great. I have seen a reduction in oil temp in the oil tank up to yes, 100 deg, plus on my dyno Jet 150 I have also seen an increase of 7 HP. Yep no other changes. I hope the explains there is a drain on the engine case, and two, take my advice and perform the update, you will go away smilin. Good luck, and stay in the wind!
Sincerely,
Fuelie
.................. see ya, time to move on
to one and all, enjoy the ride!
................ADIOS!
Old 05-08-2013, 09:45 PM
Thanks.
there are 2 allen plugs on the very bottom plate (high side). there is about a 1/2 quart of oil left in the engine.
