Last Post: chopperfugger
Kickstand Replacement or extension
New bleeder valve won’t fit:(
2007 Big Bear Screamin Demon Parts List
Last Post: eisej
Posted On: 07-21-2019
BBC Odometer Cycling
Last Post: eisej
Old 03-04-2005, 12:17 AM
Bad valve day, Ouch!
Its not often that a valve plants so squarely into a piston as this.
This is a Merch 120", this happened without fault to the manufacturer of this engine.
This is the result of a valve spring failure, a $20 part breakage resulting in a spendy repair.
Very interesting engines, no head gaskets.http://www.clubchopper.com/photopost...cat=500&page=1
Old 03-04-2005, 12:21 AM
Bike Year, Make, Engine: 2004 Rigid Springer 96" S&S
Damn! Right in the middle.
Old 03-04-2005, 12:23 AM
Ouch!! I didn't know they put quarter slots in their pistons!! LOL
Had to be a real noise maker!
Old 03-04-2005, 01:42 AM
Scooter6512's Avatar
Bike Year, Make, Engine: 98 FXSTC* * * 10" up 5" out 46* Redneck
How can they not run a head gasket? Is it like special machining between the two surfaces? Sounds itnteresting. How is the rest of the motor built? Quality stuff in there or what?
Oral sex and regular sex are not the same things....that's why they are different prices....
Old 03-04-2005, 02:20 AM
At the top of the cylinder there is a slightly raised shoulder from the cast iron cylinder sleeve ( visible in the top right corner of photo). The head is drawn down with considerable torque, and this shoulder is actually makes an impression into the head .
This makes a metal to metal contact for head and cylinder, thats good for heat transfer.
The cylinder to crankcase is sealed with orings, the oring grooves are cut into the cylinder where as twincam the grooves are cut into the crankcases.
All of this is great for heat transfer.
This is a quality engine, even has a Jims breather gear. I will have to do a complete build as alot of metal moved around, The front head sucked in metal from the rear head and bent both valves, and metal went through the hole in the rear piston to the lower end
I may take some photos of this as I build it, if there is interest in it I will post them.
Don
Old 03-04-2005, 07:56 AM
Freak's Avatar
Bike Year, Make, Engine: 10 foot of Thunder
Bullseye or what.
Now my question. Why no head gasket?
I do not know of a machining process that could result in a good enough surface texture that would allow a connection that would withstand the pressures and thermal cycling experienced on an engine.
Your explanation above would indicate that this is a one tiime event. How could anyone ever reproduce the indentation ? First valve job would require wrench (mechanic) to overtorque to even have a chance of sealing would it not?
Extensive labyrith?
Please enlighten me.
Freak
Acoustic Terrorist MC
Old 03-04-2005, 08:09 AM
onebaddog's Avatar
Bike Year, Make, Engine: 92FXSTC
Don,
Yea that baby took a shot, in the days i drag raced i seen a bunch of strange stuff happen to motors, we had one physically remove a chunk of an aluminum brodix cylinder head & cylinders 3 & 5 from a small block chevy, hell the piece of cylinder head was still bolted to the chunk of block, but it was all laying on the floor !!!! not to mention the pistons were now on the outside of the block at that point. It's pretty amazing the stuff that can go wrong or the damage that can be had from the faliure of a little
$ 20 part. Some of the nitrous junkies we raced with, would push the copper head gaskets out from between the block & heads from the cylinder pressures they ran with that stuff. I've seen em cook pistons so bad the only thing left hooked to the connecting rod was the wrist pin bosses !!!!
OBD
Foolish man give wife grand piano ~ Wise man give wife upright organ.
Old 03-04-2005, 08:43 AM
There is not alot of damage to this engine. The rear head is savable.
I was poking around on the net, and it appears that Merch may not exist again.
The rear cylinder sleeve is damaged, I may have to obtain a sleeve and install it instead of replace the whole cylinder.
It looks like Zippers may have replacement pistons. I will have to check around a bit.
Anyone have any Merch info?
Don
Old 03-04-2005, 10:51 AM
On the head to cylinder interface. The head will require refacing each time the heads or heads are removed.
The impression that occurs on the head from the cylinder sleeve will of course work harden and it would be unlikely to get it to seal without a fresh surface.
This type of seal is used in other industries where super high pressure is encounterd (high pressure hydraulics).
The two best ways to face a surface like this would be an automatic facing head in a mill type machine or mounted and faced in a lathe.
Fly cutting in a mill would leave tool marks that would traverse the inside to outside of the combustion chamber, making leaking more likely.
Old 03-04-2005, 11:10 AM
XTC Choppers's Avatar
Bike Year, Make, Engine: 2006, XTC Choppers Pro-Street, TP 124
HD, Gerry Merchant is alive and well. To make a long story short he and his partner in the now defunct Merch Performance got fucked by their accountants and lawyers (not surprising) in an effort to take Merch Performace public. Gerry left the business over 2 years before their demise and started Merch Motorcycles, with the intent of using their (his) 131" fuelie in his production Road King styled bike. After M/P went down Gerry and his partner went in and bought back all of their tooling and are now producing motors under the name Merch Motorworkz. Here is the linkhttp://www.merchmotorworkz.com/main.htm
When I have spoken with them they are very adament about standing behind the motors that are already out there. Although there is no obligation to do so because they are not even the same company. Gerry just feels because his name is on the product he will stand behind it. They also have all of the replacement parts neccessary for rebuilds. They will ask for the case numbers though because there was a guy from Texas who came to the auction and bought all of the rejected cases, flywheels,etc. and has been selling them as new M/P motors. If this motor was a valid M/P build Gerry and Bob will help you out.
IMO Gerry and Bob @ Merch Motorworkz are good peolpe and stand behind their product unconditionally.
p.s. They also have a 150" Fuelie just about ready to pop, and as we speak the 141" should be available.
XTC Choppers
866-488-9911
www.xtcchoppers.com
sales@xtcchoppers.com
Old 03-04-2005, 11:12 AM
p.s.s. If you have any tech ?'s they are available to help at the # on the web site. Good chance you'll talk to Gerry directly. Good to see these guys getting back to their roots "BIG ASS MOTORS!"
XTC Choppers
866-488-9911
www.xtcchoppers.com
Old 03-04-2005, 07:11 PM
Thanks for the info XTC, again this failure is not the fault of Merch. This motor has been run very hard.
I have the cam cover off and see no cheap stuff whatsoever.
I will try to get this thing out and disasembled in the next day or two and take some more pics.
I did flow test the front head and found it too was very good.
Don
Old 03-04-2005, 07:16 PM
Bike Year, Make, Engine: 97 rubber mnt softail 120 Merch
It's to bad they
had to take such a roundabout way to get here again ,but its great to have Gerry back in the driver's seat again.Red
Old 03-05-2005, 08:50 AM
I agree, it is great to have Gerry back in the drivers seat. Merch was doing 120's and 131's before anyone. They are the original big inch specialists and from what I understand are looking to retake their throne.
XTC Choppers
866-488-9911
www.xtcchoppers.com
Old 03-05-2005, 08:56 AM
Just thought I'd show a picture of my bike with the Merch 120" Stage II. Smokes all dem S&S motors, although I haven't had the opportunity to find a 145" yet.
[IMG] [/IMG]
XTC Choppers
866-488-9911
www.xtcchoppers.com
