Tappet block oil problems
Last Post: michelinesander
Posted On: 01-28-2024
Powder coating
Posted On: 01-15-2024
revtech 100 starts then dies
Last Post: mabelhillhouse
Posted On: 01-03-2024
Hello guys
5 speed clutch
Old 10-30-2023, 12:18 PM
Ultima Ignition Module
All,
I have an Ultima ignition module that took a shit. It was used, so I'm not really surprised. You get what you pay for right?
I need to replace it now, and wanted to see what others thought of it. I know the Ultima knock-off carburetors, as an example, are not as tunable as the genuine S&S carbs. I have several in a box on a shelf...
The new Crane Hi-4 from S&S is outrageously expensive, and I'm trying to justify the cost, or try another Ultima.
Old 10-30-2023, 03:21 PM
I got 4 years out of a new hi4,but that was 17 years ago so quality might have changed since S&S acuired Crane.Been running Ultimas since.On second one now.Both times I lost hi4 and an Ultima rear cyl. lost fire when bike was at op temp.
Old 10-31-2023, 06:15 AM
That is exactly what is happening to my bike. Any way to prevent this in the future? I know heat is a big factor, especially the added heat from the 127.
Old 10-31-2023, 05:03 PM
I've often pondered going to the stock setup under the cone cover and run a remote module somewhere.Til then the Ultima in there is doing fine.
Old 11-06-2023, 04:20 AM
I may eventually do that. Replacing the pickup is easier, (and cheaper) than replacing the entire ignition.
Old 11-29-2023, 11:34 AM
Got the 127 running well, but noticed that the cam cover is VERY hot to touch. Is this to be expected? My RK does not get that hot.
