Last Post: Choppa
Posted On: 11-30-2023
Ultima Ignition Module
Last Post: CIC2016
Posted On: 11-29-2023
How to convert audio from Persian to text?
Last Post: David_Torx
Posted On: 11-25-2023
Bling's 2" 260 rear pics
Last Post: Diego90
Posted On: 11-14-2023
Blings cycles moved?
Last Post: Diego90
Old 09-29-2023, 06:08 PM
Fork tube removal w/HHI trees
So after doing a bunch of work and giving the bike a shakdown ride,got back home cleaning it and discovered a forktube seal leaking.Trying to get the tubes out of these HHI trees with hidden caps.I put these trees on about 10 years ago and IIRC I used anti seize.Loosened the trees and tried rubber gloves and a "deathgrip",a strap wrench,leather belt and big channelocks-no dice.I'm considering useing some heat at this point.Just how ginger do I need to heat namely the upper tree where the tube screws up in there?Heat gun or propane torch?Thanx in advance......
Old 10-02-2023, 01:25 PM
PB Blaster may loosen it. That and heat are most likely your only options
