Last Post: Choppa
Posted On: 11-30-2023
Ultima Ignition Module
Last Post: CIC2016
Posted On: 11-29-2023
How to convert audio from Persian to text?
Last Post: David_Torx
Posted On: 11-25-2023
Bling's 2" 260 rear pics
Last Post: Diego90
Posted On: 11-14-2023
Blings cycles moved?
Last Post: Diego90
Old 09-20-2023, 05:56 AM
Hi. I am new to Choppers but have been around motorcycles my entire life. I just picked up a custom built chopper and noticed that the transmission is leaking from the bottom. The drain hex bolt was a loose so i tightened it up a bit but still leaking. From the picture i uploaded, does it look like it leaking from the gasket? Does anyone have experience with this transmission? Sorry if this is a newbie question but i do appreciate the help
Old 09-20-2023, 01:43 PM
Ocassionally those studs do leak. It just depends on if the machining process went all the way through the case. Some are blind holes so they will not leak. On those that are leaking I'd pull the stud and apply a layer of silicone sealant to stop it from leaking through the threads.
Old 09-29-2023, 06:12 PM
Really need to clean that up,run it a bit,then check it to better isolate the source.Could be stud or gasket-hard to tell with oil spread everywhere.
