Posted On: 09-29-2023
Fork tube removal w/HHI trees
BDL 3" open primary jackshaft
Last Post: CIC2016
licanse plate for modified BDL Jacksaft cover
Last Post: CIC2016
Posted On: 09-28-2023
5 speed trapdoor bearings
Posted On: 09-21-2023
Old 04-30-2023, 05:22 AM
EVO nose cone
All,
I need to change the nose cone on my scoot, and it has a long tube for oil on it. I have a couple of other nose cones that do not have this tube, but don't know what year they're from. What year(s) had these tubes in the nose cone?
Thanks!
Old 05-01-2023, 09:32 AM
Do you have any pics? What year is your bike? What motor size are you running and what brand? SS, Revtech, Harley?
Old 05-10-2023, 07:01 PM
The cam cover with the tube is for a breather case engine. 70-93. The cover without is a breather head version 94-99.
When I built the engine in my hotrod FXR I used a breather case with the newer style head breather cam cover and breather heads to help vent the crankcase better. The key here is the cam cover gasket has to match the era of the cam cover. The early cover uses a gasket that seals off the breather cavity.
The 93-99 Cam cover gasket just seals the perimeter of the cover
https://cdn11.bigcommerce.com/s-0m9u...548763.jpg?c=2
Old 06-04-2023, 05:46 AM
Got it! I want to change this out with a polished cover, but can't get Carlini to make me a new torque plate! There's apparently no one else on the planet that needs a torque plate for an EVO to 6 speed transmission. They won't make just one unfortunately.
The last bike I built, I did not use a torque plate and cracked my BDL aluminum inner primary
