Badland Digital Mirror Installation Question????
Last Post: MAKO6
ignition module or something else?
WCC Dominator frames
Last Post: modekko
AIH Fuel Hose Routing
Last Post: crf311
Posted On: 01-18-2021
NEW YORK FREEDOM RIDER NEWS- 1/15/21 - motorcycle related updates
Posted On: 01-15-2021
Old 07-17-2020, 03:57 PM
mudtrux's Avatar
UGGHHHH What trans do I have?? (5 speed softail)
I have a 98 evo, with A/M frame and what I was TOLD is a RevTech 5 speed trans.
I'm having problems getting my Ultima open primary clutch hub to fit.
Friend suggested I look up the trans to make sure what it is.
Only # I can see is N5825.
Any idea what this is built for? Has worked well.
Thanks for any help.
Mud.
Old 07-18-2020, 10:19 AM
Mud.
What do you mean to fit?
Is it just matter of spacing? Or the basket doesn,t slide on the shaft at all?
Remember, if you had a closed primary, the bearing setup is different . There,s a sleeve, a racing you have to pull out of the main shaft in order for sealеd bearing of the ultima primary to go in.
I have exactly this combination of revtech transmission circa 90s and ultima 2” primary, like 20 years younger. They fit just fine . Never mind the auto clutch- that came later.
Old 07-19-2020, 09:52 AM
mudtrux's Avatar
STEINBVG,
I don't know when you'll see this but, any chance I can call you and maybe send you a pic or two?
I don't internet on my phone so I need to check back on to my PC to get here.
Sending PM with My #
Thanks for the reply.
