Alternator/rotor
Hi guys, Dave in Wales, starting a new build, anyone have any luck with the charging setup on a twin cam with 88 cases and 96 crank? Crank has fine splines, primary will be 94-06 softail, can get round front sprocket/alignment issue with Vulcan solid item, but the rotor/stator combination is something I want to address, haven’t got parts to cross check so difficult, if someone has done it or has a steer would be appreciated, I know it would be easier with early/stroker crank but that’s not an option just now. Dave
