Last Post: bjh
Worth Chopping?
Ultima 113
Posted On: 06-04-2020
Last Post: Southpaw1746
Posted On: 06-03-2020
Old 04-13-2020, 01:46 PM
Big Bear Oil Tank Fittings
I recently inherited a Big Bear basket case.
Just to clear the air the neck has a nice big fat gusset.
Anyway, for the life of me I cannot find / figure out the fittings for the oil lines.
The oil tank has 4 threaded bungs, three on the face and one on the bottom.
I have been through all the fittings I can find at Lowes and Home Depot and cannot find anything.
Don't want to waste a bunch of money on ebay ordering stuff without knowing if it will fit.
Any help would be appreciated.
Old 04-13-2020, 07:56 PM
Off the top of my head I would say they are 1/8 NPT. Maybe try to clean them up with a tap.
Old 04-14-2020, 05:34 AM
I've tried every fitting at the hardware store including 1/8 NPT.
Threads have a little surface rust but not enough to prevent proper thread alignment/fitment.
Old 04-14-2020, 10:36 AM
You would probably have better luck using a tap set to find the size..Those are usually some oddball size on those oil tanks and are fine threaded, maybe take the tank to someone and see if they have a tap that will fit ..hopefully it will have the size on it, unless it's from China.
Old 04-14-2020, 05:03 PM
My buddy says they're 1/4" NPT...
You have to clean them out with a tap anyways so check that one. I think 1/4" NPT is too big
Old 04-24-2020, 11:18 AM
joebudd's Avatar
Bike Year, Make, Engine: 2007 Big Bear Chopper DA prostreet
This is the guy you want to talk to. He was the owner of big bear choppers. Always willing to help.
(909) 478-7788 Kevin@BigBearPerformance.com
