Wcc parts wanted
Last Post: wcb007
Last Post: CIC2016
Last Post: SKT
Posted On: 01-26-2020
Last Post: SKT
Last Post: SKT
Old 08-09-2019, 02:00 PM
I need to know how long to order the clutch cable, throttle cables, and brake line down to the junction over the front fender. I currently have 4" risers, but will probably put stock 1" risers back on.
I usually wait until I get the bars, measure each travel length, and order accordingly. I'm trying to cut that step out and get back on road ASAP.
Thanks!
Old 08-09-2019, 05:27 PM
Thanks!
You will know approximately where the handles will be. Perhaps you can use a 16gage wire to simulate a cable or a brake line, run it through all the bends and see how long it is. Compare to the current cables / lines , see how many inches+ Is necessary
Just a thought.
Old 08-10-2019, 02:51 AM
Was hoping someone had already done this with lengths of them. Not having bars would make it too inaccurate.
Old 08-10-2019, 01:06 PM
Stock cables will usually fit a 12" bar on a Roadking. Sometimes you have to reroute the clutch cable and sometimes you have to go to a +2". On the brakeline you can go 2-4" over since we typically rebend the stock stuff to get the desired length in the shop without replacing cables. Call me I can hook you up if you need lines or cables
