Club Chopper Forums
-   -   5 speed quadseal and enclosed primary (http://www.clubchopper.com/forums/shop-talk/122868-5-speed-quadseal-enclosed-primary.html)
Am4wag 07-12-2019 08:51 PM
I've been riding this bike for 13 years/50,000+ miles.Stock H-D,bought new.So where exactly does this seal go on a '99 softail 5 speed?I thought it went between the sprocket spacer and drive gear,but it seams JUST large enough that the spacer won't seat up to the drive gear.
Also,theres 7 nylon washers that are in a James primary gasket set I have for a '92 primary (inner/outer) running stock chain drive.
pushrod243 07-13-2019 08:51 PM
Does your spacer have a tapered edge? It should clear the quad seal if the tapered edge is towards the inside
Am4wag 07-14-2019 06:21 AM
Yes it has a taper.Old quad ring was cut.Probably why there was a leak AND the sprocket nut was loose upon disassembly-not drawing up.Maybe pinched-why I'm at a stop because the new one doesn't want to "draw into" the taper when compressing the spacer to the drive dear snout leaving a gap between the two.
