9 brake help
Last Post: ward2699
RedNeck
21 x 2.15 wheel 60 spokes
Last Post: donald branscom
Posted On: 05-21-2019
Wheels Needed 21x2.15 & 18x10.5
Engine swap
Last Post: chopperfugger
Old 10-03-2018, 02:16 PM
battery charging issue
Hi everyone. Have a problem with battery charging on my custom built bike with twin cam motor. Couple days ago I've started the bike and noticed that battery is not charging. So after readind this forum I've tested my alternator with multimeter. Disconnected regulator and tested wires for continuity between either stator pin and the engine crankcase. No reading. Then checked resistance between the stator pins. About 0.2 ohms. Then tested voltage on alternator pins. About 16V on idle increasing to 32-36V when turning the throttle
The only thing I've noticed that if I measure voltage from alternator with disconnected regulator it shows 16-36V. But when I've tried to measure voltage with connected regulator on the same place (using bridge wires between plugs) it shows only 1.5V and no changing when turning throttle. is it correct?
So I have no idea is it bad alternator, or regulator or both.
Forgot to say that before I've noticed a problem I've started bike using additional same battery cause a battery on bike was abit low. Could this be a problem? Ive done this before couple of times and everything was ok. Disconnected additional battery when the bike started
thanks
Old 10-03-2018, 02:56 PM
Step by Step Instructions for Testing Your Harley's Charging System | J&P Cycles Blog
Old 10-03-2018, 06:29 PM
Sounds like your stator is breaking down under load..it can test fine with out the regulator hooked but if you have a burn in a winding , it will short and drop all voltage when a load is applied .......A very easy sure fire test is to hook
a high current appliance across the stator, like a heating element out of a dryer..or toaster..if it gets warm, then your stator is ok...I went through it all on my twin cam..and that test told the story..I still have the heater hanging on my wall in the shop.
Old 10-04-2018, 01:14 PM
STEINBVG, Shovel52 thanks for your help.Half of the tests I've already done, will try to test my regulator like is written in istruction from above link. And will try to test my alternator under load. Thanks
