administrator contact
Last Post: saulcid
Posted On: 02-20-2019
Last Post: saulcid
Posted On: 02-19-2019
Last Post: hansheathen
Selling the Shovel
Last Post: madmastiff
Posted On: 02-18-2019
WCC maltese cross air cleaner
Posted On: 02-17-2019
Old 07-07-2018, 10:55 AM
instant's Avatar
2 into 1 exhausted blueing at connection
Always seen bluing at the port,but not way down a pipe. What causes this? Too rich or too lean?
Old 07-07-2018, 01:22 PM
Neverlost's Avatar
high temps coming out of the head. Every motorcycle on the planet does this..
Old 07-10-2018, 08:11 AM
Poop's Avatar
Punchbowl Lifeguard
the smoother your exhaust flow, the less this will happen. hot exhaust gasses swirling around rather than flowing out dump more heat into pipe per square inch. this is not unusual for the collector portion of a 2-1. the interaction of exhaust pulses from two headers will always have some turbulence. getting these two pulses to work together, to alternatively slip by one another and help pull each other through, is the science and art of exhaust tuning.
Old 07-10-2018, 08:40 PM
Sounds like an air leak is making you lean right there..
Old 07-26-2018, 09:04 PM
Rich = Fuel to cook.
Lean = Glows orange as if turning off the acetylenef and the oxygen stayed on.
Old Honda CB750 trick = Pipe within a pipe. You can't see the blue.
Bottom line = Normal.
