Last Post: Southpaw1746
Last Post: Ragnar1970
Ultima 113
revtech to baker trans swap
Last Post: bjh
Posted On: 05-30-2020
Old 06-14-2018, 07:17 PM
Wiring Issues, or Not?
Okay, I have two choppers, bought both of them used, just stating the fact that I didnít wire them. Each bike has minimum wiring, headlight and taillight/brake light. Both have constant hi beam, no low beam switch and a starter solenoid push button.
All of the wiring diagrams I see on here show breakers and/or fuses, these bike donít have any.
Iíve had zero problems so far but, am I in danger of something burning up, or something else leaving me stranded?
Iím trying to get to the bottom of this issue because Iím in the process doing a complete tear down and rebuild and want to make sure itís done right.
Thanks,
Old 06-15-2018, 09:06 AM
Of course it's gonna burn up - that's what the breakers are for
Old 06-15-2018, 10:48 AM
Neverlost's Avatar
Thanks,
After building and wiring my bike myself ..I would start with a new Scooters wiring harness.. I've had zero problems for years..It makes wiring SIMPLE..
Old 06-15-2018, 06:14 PM
Okay, heres one more stupid question, what causes wires to burn up, bad grounds after a while, wires wearing thin and contacting the frame, and just a bunch of other unknowns?
Old 06-16-2018, 01:33 AM
EdCase's Avatar
Wires chaffing and shorting to ground/earth will cause an unprotected cable to heat up like a heating element, melt any plastics or rubber they are touching, and possibly burst into flames if not detected soon enough and getting your battery dissconnected.
This can also happen if a component brakes down and shorts to ground/earth, or even having a bad ground/earth will cause cables to get hot.
So just imagine parking up at night with a problem you don't know about and waking up to a BBQ'd bike the next morning all cos you didnt fit fuses.
And worse than that... If it's in your garage, will you still have a home the next day?
Sounds extreeme but it could/can happen.
For the sake of a couple of pennys I know what I'd do.
Tea is for mugs
Old 06-17-2018, 06:07 PM
Thanks for the info, I appreciate it. Iíll definitely make it right on the rebuild.
Old 06-18-2018, 02:57 AM
EdCase's Avatar
No problem man.. Glad I could help
Tea is for mugs
Old 06-18-2018, 07:39 PM
Did you go with a full harness or the little module with 5 or 6 wires?
Old 06-20-2018, 02:13 PM
Neverlost's Avatar
Just the basic. The one without blinkers ect...Its a chopper.. Remember just one wire at a time..Its not so over whelming then.
Old 06-26-2018, 09:27 PM
Just add a main breaker between the battery and the main power feed for extra insurance. Our harness uses a main 30A breaker and 2 15A. One for ignition and other for the lights. Pretty easy to add those as well the gotta get power off the main feed or direct from the battery
Old 06-27-2018, 03:32 PM
Thanks for the info, Iíll get back with you when I start the rebuild.
