Last Post: CIC2016
What are these?
Last Post: EdCase
Black Chrome
Last Post: EdCase
Posted On: 03-28-2020
Old 06-02-2018, 11:46 AM
Bdl 3 inch belt drive
I'm installing a bdl 3 inch open primary on my 02 bourget low blow... . the issue in having is getting the pulleys and belt on to the shafts belt is too tight can't even get them started !! I've been in touch with bdl tech and went as far as sending them my belt and they replaced with a slightly longer one still no luck !! Any thoughts or info would be greatly appreciated !!
Jack
Old 06-02-2018, 07:05 PM
I had a fight with mine too..Have you tried to barely start the belt on the front pulley, and then with the rear pulley off of the bike, barely start that one, and then shove the pulley on...then tap the belt with a hammer and a 2x4 laid across the belt to drive it home..
Old 06-02-2018, 07:26 PM
That's not gonna work because both pulleys have a lip on the outside side !! Thanks tho
Old 06-03-2018, 07:00 PM
It took me a little while to figure it out. I just started the front and then did the same with the rear. The lips on the pulleys has nothing to do with it.
When the belt was new I'd let it heat up in the sun for a few hrs.
Old 06-04-2018, 02:04 PM
No matter what I try I can not get both pulleys started with belt attached !!?? I'm about to put back on my primo brute111 enclosed belt that assembles just fine !
Old 06-04-2018, 02:12 PM
No matter what I try I can't get both pulleys started with the belt attached !!?? I think ill reinstall my primo brute111 which assembles just fine and call it a day ! Don't have time for this aggravation !!!
Old 06-05-2018, 06:32 AM
I thought primo was always better
Old 06-05-2018, 09:05 AM
My bdl does not have a lip..Why would they start making something like that?
Old 06-05-2018, 12:34 PM
The two 3" BDL pulleys on my Big Bear had lips (07). The custom bike I ride now has a 2" BDL, it only has a lip on the back pulley. This is also from 07.
Old 06-05-2018, 03:59 PM
ecir45's Avatar
pull pulley and hub install belt then put together like manual says to do a chain, worth a shot.
113" El Bruto / 5 speed
Old 06-06-2018, 02:23 PM
Gave up on the bdl for now put the primo brute 111 back and install a cycle electric alternator kit while I had it apart !!! I want to ride instead of messing with that bdl !!!
Old 06-20-2018, 03:01 AM
i've been running 3" BDL for 15 years on multiple builds without any issues with installation. Are you running the inner primary that BDL supplied? This is the correct distance for the pulleys. I also have always started both clutch hub and front pulley on at the same time. It is VERY tight, but has always gone on. As for PRIMO vs BDL, no difference in performance, just looks and price
Old 06-20-2018, 03:02 AM
if you want to sell that BDL, hit me up!
