Last Post: SKT
Posted On: 01-21-2019
Last Post: Boltaction
Posted On: 01-20-2019
Last Post: birrelly
Posted On: 01-19-2019
Evo cam swap
Posted On: 01-18-2019
Tire rub chain
Old 04-13-2018, 03:35 PM
Changing tire without tools
I was dreading changing this front tire because of the aluminum wheel...They powder coated it and sprayed it with thick clear coat..I ended up just shoving the tire on by hand... no tools..The trick is to compress the tire with cable ties as you work you way around so that both lips are inside the center part of the rim...that makes the rim about 3/4 of an inch smaller and also makes the tire larger..wd40 also makes the job easy..just clean it up with gas..
Old 04-25-2018, 02:49 PM
can you show this?
Old 04-25-2018, 07:49 PM
There are several you tube videos on it, here is one ..
https://www.youtube.com/watch?v=U9MpgD-xIjg
