Last Post: SKT
Posted On: 01-21-2019
Last Post: Boltaction
Posted On: 01-20-2019
Last Post: birrelly
Posted On: 01-19-2019
Evo cam swap
Posted On: 01-18-2019
Tire rub chain
Old 04-01-2018, 04:16 PM
Bike Year, Make, Engine: 2007 ULTIMA / 1999 HARLEY
Oil Dumping From Lower Vent Tube
Here lately my custom S&S 96 cu in chopper dumps oil out on the ground when trying to start it. it seems to only do it if it has been sitting awhile. Also, when trying to crank it up it does not want to turn over properly(slow) not enough to fire it up. starter terminals smoking from strain . I have checked battery and its fine/fully charged.
What could be causing this?
Old 04-01-2018, 11:26 PM
Its called "sumping" .......your check valve/ball is probably dirty. Do a search on sumping, you'll find out all you need to know.
Just couriuos, what kind of oil are you using?
Old 05-30-2018, 04:56 PM
I had just some 20 50 pensoil i think . I usually run synthetic . UPDATE: I rebuilt oil pump with S&S rebuild kit. Now I still cant turn motor over. . I put two quarts in it . it is VERY hard to turn over . starter smokes from getting hot. . I pulled the plugs out and it will turn over fine. . do i have another issue. What can I do ? I cant get it to crank over enough to fire up.
Old 05-30-2018, 09:09 PM
If your starter is smoking from turning over slowly, I would pull it apart and look at it, if it is black inside then it is not going to last much longer..I went through that ...cleaned it twice......bought a new starter...not fun pushing that thing..
Old 06-05-2018, 07:00 AM
instant's Avatar
Recheck all your connections are tite and clean
Old 06-05-2018, 07:03 AM
instant's Avatar
Oil discharge happens to best of us. Bikes done like to sit. Oil finds its way by check valve. And gets spit out on startup. Sucks
