administrator contact
Last Post: saulcid
Posted On: 02-20-2019
Last Post: saulcid
Posted On: 02-19-2019
Last Post: hansheathen
Selling the Shovel
Last Post: madmastiff
Posted On: 02-18-2019
WCC maltese cross air cleaner
Posted On: 02-17-2019
Old 01-24-2018, 12:54 PM
exhaust gasket: flat vs tappered
Does it matter which of these you use. I see both are recommended for just about all HD engines made since 1984.
Old 01-24-2018, 02:45 PM
EdCase's Avatar
Ive always used Cometic tapered wire gaskets on both my twin cam and Ultima with no problems.
Same as these on eBay -
https://www.ebay.co.uk/itm/COMETIC-H...19.m1438.l2649
Tea is for mugs
Old 01-24-2018, 07:42 PM
ecir45's Avatar
depends on if the pipe ends are flat or tapered.
113" El Bruto / 5 speed
Old 01-25-2018, 09:01 AM
Interesting, 2 sets of ultima growl pipes i bought for my ultima engines came with funky looking seemingly crash-able tin gaskets[ not wire mesh] .
They fit perfect in the ports.
Old 01-25-2018, 12:21 PM
Neverlost's Avatar
I use factory harley screaming eagle flat ones on all my pipies
Old 01-29-2018, 04:48 PM
they both work
Old 01-30-2018, 12:35 AM
Neverlost's Avatar
Yeah I had a set of those they looked funny, I never did use them. Im sure they are fine..
Old 01-31-2018, 05:42 AM
chuck1073's Avatar
Just used a set of round copper gaskets when I changed out to a short 2-1 pipe on the Texas chop. Had to use the low profile type with the torque cones. Super easy to use.
'72 Ironhead Digger
'07 AIH Texas Chopper
Old 01-31-2018, 10:03 PM
The small flat round gaskets we typically use for performance. The cone shaped seal better but have a tendency to squish into the port restricting the flow a tiny bit. Not sure how critical the obstruction is but I have the small flat ones in my hotrods 113. Some guys will stack 2 sets of the small ones foe a little better crush and seal. They both will work in any evo or newer engine.
Old 02-01-2018, 04:14 PM
Its been a while since I wrenched so much on a custom. It took me a while to remeber why I used the tapered gaskets on my last bike. The thicker tapered gasket set the pipes out just a little bit more , just enough to fit the bottom exhaust mounts.
BtW John, thanks for getting "The Fix" Jackshaft in the mail so fast.
