Wiring Issues, or Not?
Last Post: DeafBillyGoat
Buell XB12 Chopper
Last Post: FRANKTHECRANK
Educate me on my bike
Posted On: 06-07-2018
Last Post: IHCKoy
Old 12-04-2017, 04:54 PM
shift linkage
putting true duals on a 1998 Heritage. the cross over pipe comes out on the left side where the shift lingage is. a shift linkage made with a curve or dip or an extention to the trans. shift shaft raising the linkage over the pipe would work.
anyone know of any products already made that would eliminate interferance between linkage rod and pipe?
parts picker
Old 12-07-2017, 03:21 PM
Cut it, weld in bend you want, then finish of choice, (paint, powder coat, polish, etc).
Or try this....
https://www.samsonusa.com/shop/a-256-shift-rod-linkage/
Old 12-10-2017, 06:00 PM
thanks CIC. found a taillight extention that will fit over the trans shift lever. already drilled with two holes at top. extends shift rod high enough to clear pipe.
parts picker
