Oil Lines
Last Post: Maustarman
Posted On: 08-14-2019
Bars upside down
Posted On: 08-12-2019
Posted On: 08-10-2019
Last Post: donald branscom
Posted On: 08-09-2019
Project Blast!
Posted On: 08-08-2019
Old 12-02-2017, 07:02 AM
Originally Posted by CIC2016 View Post
I run a 300 rear and 21 speedmaster up front. Both are mic'd in perfectly and the bike is left side heavy without any offset, even going straight. Having the primary sticking out on the left with all of the other heavy Harley bits, makes it that way.
Wow, 300 tire with LSD? That,s a radical setup.
Although. Walz Hardcore Cycles runs his bikes consistently with 250+ tires and stubbornly uses LSD i guess for clean looks.
I wonder how he gets away with left sid3 being heavy an dell his bikes for 60-70k
Old 12-02-2017, 02:29 PM
Nope, RSD. I failed to mention that
Old 12-02-2017, 04:59 PM
Strange, that with such a setup it,s not balanced. What could be heavy on the left side? Do you have something like 4” belt drive with outside bearing support?
Old 12-03-2017, 10:28 AM
I think it's just the way this rig rides. Doesn't lean or anything, it just doesn't ride like my Dyna!
Old 12-03-2017, 12:05 PM
Funny thing, my Walz Hardcore frame was originally set for LSD, before 250 tires came to market, 230 was the king. Eauropeans were blowing the tire up on 15” rims as wide as 10-11”. I had 10”. Had to put the tire on with an explosion in order to seal.
I had 0.5” offset in the motor, +rear chain drive and still needed about 2” offset in the tranny/ primary. Now, THAT was left side heavy despite any modifications/ experiments with weight.
Eventually I couldn,t take it , I switched to Rsd , a new swing arm, + new 300 rim/ tire . That eliminated the trany offset, but the engine offset remains. I centered the wheels using a string and, perhaps by luck have great balance with my new setup.
I couldn’t stand even slight one sided pull on the bikes, with time it,s a bit fatiguing. . It is a pleasure to ride a bike that plows dead center and you can let go the handlebars.
I don,t know, perhaps extra weight on the light side- like a heavy tool bag might do the trick if necessary.
Old 12-04-2017, 03:08 AM
The first couple of bikes I built in 2000 had the 0.5" and 1" offset on the primary to accommodate a 200mm tire. That seems so archaic looking back on what had to be done to get a puny 200 on! There is no offset on my rigid 300, and I am able to ride down the road without hands.
In the beginning, when I was first figuring this bike building thing out, I didn't have everything lined up perfectly. I learned through several builds, that EVERYTHING from front wheel spacing, engine, transmission, belt/chain, and rear wheel all need to be perfectly straight. I have made countless wheel spacers to get everything perfect. It certainly has made tire wear and readability better.
