Back again!
Last Post: Daxcobra
Weird constant alarm sound?
Last Post: ecir45
Posted On: 02-22-2018
Posted On: 02-21-2018
Old 10-03-2017, 01:43 AM
wolfchopper's Avatar
Bike Year, Make, Engine: Big Twin
adjustable pushrods differences
hi,
i found that there are many different types/makes of adjustable pushrods.
there are those that must to be installed by removing the rocker covers, others that
can be installed simply by removing the pushrod tubes.
i came across two s&S adjustables that i want to use in my evo engine. the 'time saver" and the 'quickee' pushrod.
what are the differneces between the two?
which one would you recommend?
both can be installed without removing the rocker covers.
riders on the storm
Old 10-03-2017, 09:44 AM
I have always seen the quickees associated with a twin cam and the timesavers with an EVO but I do see they list both for the evo on some sites.....As long as they are for an EVO either should work for you.
Old 10-03-2017, 02:21 PM
which one is the better one in terms of solidity?
can the standard pushrod covers be used?
riders on the storm
Old 10-06-2017, 02:45 PM
Neverlost's Avatar
The ones ive used are different so you can get a wrench on them to adjust..
Old 10-06-2017, 09:00 PM
Yes on the pushrod covers. I do not know if one is stronger than the other. I have never had both in my hands at the same time.
