Last Post: Southpaw1746
Last Post: Ragnar1970
Ultima 113
revtech to baker trans swap
Last Post: bjh
Posted On: 05-30-2020
Old 09-22-2017, 09:01 AM
oranges3's Avatar
sump drain plug stuck/stripped
S&S 113" sump drain plug, the drain plug directly below the crank, is stuck and stripped.
any advice on how to remove?
Old 09-22-2017, 04:53 PM
Stripped..you mean you cant get a wrench on it, how about a small pipe wrench?
Old 09-23-2017, 04:08 AM
an easy out. Once out, I always use teflon pipe thread or antisieze like you would on spark plugs. Good luck!
Old 09-23-2017, 07:47 AM
oranges3's Avatar
easy out worked with a little heat...
replaced with a steel differential plug.
much nicer fit.
Old 09-24-2017, 02:02 AM
glad to hear it! using the teflon helps keep it sealed, while not having to overtightening it.
