TP engineering 107
Posted On: 02-23-2020
Posted On: 02-21-2020
Posted On: 02-20-2020
Old 07-25-2017, 03:20 PM
Angry S&s super g carb trouble
I'VE HAD THIS S&S SUPER G CARB SITTING ON A 113 ULTIMA MOTOR REBUILT 3 TIMES AND IT STILL CHUGS AND SPITS N SPUTTERS IN 1st n 2nd DOES ANYBODY HAVE A SOLUTION? I'VE CLEANED THE TANK OUT AND RED KOTE'D THE INSIDE CHANGED THE FUEL LINES AND NO CHANGE.
Old 07-25-2017, 04:15 PM
What kind of air cleaner are you running? Instead of waiting for a reply , have you tried varying air flow at the filter to determine if you are rich or lean?... That would tell you a lot..
Old 09-09-2017, 08:00 PM
Lazer's Avatar
Check and see if your covering the vent hole on the carb inlet ,that little hole being covered can cause issues, also the carb may not even be the problem ,check your intake for leaks ,,your problem could also be electrical or ignition related, the first thing we attack is the carb when a problem crops up, often the problem can lies elsewhere.
