bmc wiring diagram
Last Post: bluballin
Posted On: 07-04-2020
Identify Frame *Help
Last Post: Maustarman
Last Post: erlobulldog
Posted On: 07-02-2020
Posted On: 07-01-2020
Old 06-23-2017, 12:17 PM
Wicked50's Avatar
Brembos on a chopper
So I have a rigid frame with a 200mm rear tire and a narrow sportster front end with a 21" spoke wheel. Has anyone ran real Brembo calipers not the Harley type but the calipers found on Ducati and Aprilla sport bikes.
Old 06-23-2017, 01:38 PM
Yep I have them on 3 of my bikes, pretty economical.
2 piston: P32s, F08s and 4 piston : P4 30/34s
Just made custom mounting plates.
Old 06-23-2017, 02:00 PM
Wicked50's Avatar
What size forks and what kind of front wheel are you running
Old 06-23-2017, 02:15 PM
harley springer repop 4 under
Another Harley springer repop 2 under
And one off , 12" over 49 mm tubes, I made with the Fat a bob lowers and Stortz 7 degree trees. Dual front Brembos p 4 30/34
Old 06-23-2017, 02:22 PM
Wicked50's Avatar
I'm wondering if these calipers are narrow enough to run on a narrow glide fork with a narrow glide wheel the fork tubes are 7" on center. I think I measured 2 3/16" of the caliper tab on the fork the spokes
Old 06-23-2017, 04:53 PM
I will try to make a clear picture for you with the measurement tape for reference so you can see the sizes and distances.
There were no issues with wide glide chopper.
But the repop springer is very narrow, but I was able to setup dual caliper front brake system , however the wheel is wide glide. In this setup I use two p 32 calipers
Old 06-24-2017, 11:20 AM
Wicked50's Avatar
Who sells 2 piston caliper hangers for a rear brake on an 11.5" rotor
Old 06-24-2017, 11:40 AM
I am pretty sure FabKevin does. Google it he has a website
Old 06-24-2017, 01:53 PM
I made mine from 1/4 steel flat with a hand grinder. Pretty easy using carboard for measurements , positioning of the caliper etc. Once I roughed up the bracket, I marked the holes while holding the caliper on the rotor, not allowing it to bottom out. A wire tie of right width place on the bottom of the caliper slot will place it perfectly on the rotor.
Perhaps easier done with aluminum flat , like 3/8" vs 0.5" thick.
Here's front for springer. Has to have bushings . F08 caliper Grimeca/ Brembo
Here's dual caliper rear brake with the same calipers. Hangs from the 3/4 rear axel and has a long slot upfront to be held in place by a typical tab on the frame.
Old 06-24-2017, 02:21 PM
Here's how it works on wide glide front end. The tape is touching spokes. Looks like the caliper is ~3" thick". I was lucky: the 1/4" flat bracket perfectly centered them on the rotors. Was no need fo 3D mill work.
Old 06-24-2017, 09:27 PM
Wicked50's Avatar
So I measured from the inside caliper mount tab to the wheel and it's 2 3/8"so the caliper won't work I may have to get some 39mm mid glide trees
Old 06-26-2017, 12:11 PM
Wicked50's Avatar
Thanks John, I talked to FabKevin and he said he can make one he just needs to the caliper to get the mounting holes and measurements right
