Posted On: 05-29-2020
Last Post: juanba
Posted On: 05-27-2020
Rear wheel spacer
Posted On: 05-26-2020
Posted On: 05-25-2020
Old 06-13-2017, 03:29 PM
Mikuni
I' m not familiar with these carbs . What is the nose in the middle of the back of the carb
Forever Two Wheels
Old 06-13-2017, 06:57 PM
The vacuum port or the emissions port?
http://www.mikuni.com/pdf/hsr_tuningmanual_021003.pdf
Old 06-17-2017, 04:28 AM
So do I block this off if I change to a single petcock
Forever Two Wheels
Old 06-17-2017, 09:43 AM
If it's the vacuum port then you use it for the VOES(if you have one) and/or the vacuum operated petcock(if you have one), otherwise you just cap it.
Old 06-17-2017, 09:46 AM
It's the port in the middle of the carb the voes is already capped off
Forever Two Wheels
Old 06-19-2017, 05:30 PM
Block it off.
Old 06-23-2017, 03:10 AM
Sounds like the vent fitting, do not block it off if it is. Check via mikuni tuning manual diagram. I fitted a bit of fuel hose to mine just to extend it down a bit to keep water out from washing. hope this helps...........or could be purge fitting if it is in the middle of back of carb used with emissions kits should be blocked off...........
Old 06-24-2017, 10:36 AM
I took everything apart AGAIN and it looks like the voes is still hooked up. I have a pingle to put on with out a vacuum hook up. The bike has a screaming eagle ignition box I'm blocking off the voes on carb. Am I going to have any problems
Forever Two Wheels
Old 06-24-2017, 06:00 PM
If your ignition box is set up to run a VOES then you should run one, if it has a no VOES mode then you can eliminate it.
Old 06-25-2017, 05:03 AM
Got it. I'll keep you updated. Thanks for the help.
Forever Two Wheels
Old 07-10-2017, 04:02 PM
OK guys the problem was the petcock. I put a pingel on blocked off the vacuum line to the petcock and it started right up.
Forever Two Wheels
