bmc wiring diagram
Last Post: bluballin
Posted On: 07-04-2020
Identify Frame *Help
Last Post: Maustarman
Last Post: erlobulldog
Posted On: 07-02-2020
Posted On: 07-01-2020
Old 06-09-2017, 08:37 AM
christok's Avatar
Bike Year, Make, Engine: 2009, saxon custom,S&S
Shorten chain yes or no
I still have a bit of room to tighten my chain with the adjusters however by moving my wheel back a bit further i would be reducing the clearance between my fender and my tire (softail Saxon Griffin) andclearance is already at a minimum. My chain is loose and needs to be adjusted. Is there any problem removing a link or two from my chain as my sprockets and chain all seem to be in good shape. 530 oring chain on the bike.
how many links should I remove if okay to remove links
thanks
Mold your dreams into reality
Old 06-09-2017, 10:54 AM
Originally Posted by christok View Post
i still have a bit of room to tighten my chain with the adjusters however by moving my wheel back a bit further i would be reducing the clearance between my fender and my tire (softail saxon griffin) andclearance is already at a minimum. My chain is loose and needs to be adjusted. Is there any problem removing a link or two from my chain as my sprockets and chain all seem to be in good shape. 530 oring chain on the bike.
How many links should i remove if okay to remove links
thanks
I see no issues, as long as you don't make it too short...
I hope it stretches evenly, because if you have significant high and low spots, you may want to consider a new chain.
I would go with the Ek 530 x ring chains with the most tensile strength available...
Old 06-09-2017, 05:20 PM
In the past I have always removed two... to start with...replace it with a master link and then you are one link shorter...then go from there..
Old 06-09-2017, 09:40 PM
Yup, no issues with removing a link.
