bmc wiring diagram
Last Post: bluballin
Posted On: 07-04-2020
Identify Frame *Help
Last Post: Maustarman
Last Post: erlobulldog
Posted On: 07-02-2020
Posted On: 07-01-2020
Old 06-03-2017, 05:59 AM
christok's Avatar
Bike Year, Make, Engine: 2009, saxon custom,S&S
Help - swingarm chain wear guard thingy?
Not sure what to call it but on my Saxon chopper there is a teflon or white plastic piece sitting in a notch in my swingarm near the pivot point under the chain. It seems to prevent wear to both the chain and the swingarm and the swingarm seems to have been made so that this part sits on top of it (bolted or riveted in place). Mine is worn out and I am afraid that the chain will soon be hitting the metal of the swingarm. Does anyone know what this part is really called ( wear guard, chain protector etc.) and does anyone know where I can find a replacement. My bike is a custom made chopper made using saxon Griffin parts but I am not sure that this is a stock saxon frame and the shop that originally made the bike no longer exists as the builder died.
any help would be appreciated
Mold your dreams into reality
Old 06-03-2017, 07:33 AM
Show the picture.
I believe nylon is the material to use. There,a bunch of options of additives in it making it more durable and slippery. You might want to cut a right size piece from a stock bought from McMaster Carr https://www.mcmaster.com/#standard-n...heets/=17wpwq2 or
https://www.mcmaster.com/#standard-n...heets/=17wpx9g
Old 06-03-2017, 09:28 AM
I used a piece of 1/16" thick stainless steel on my swing arm to protect the paint from the occasional belt slap.
Old 06-04-2017, 05:21 AM
Wthout a picture, I am going to guess you will need to shape a piece of UHMW. They make an oil impregnated version of it too.
Old 06-04-2017, 01:52 PM
christok's Avatar
here are some pictures. hard to see as it is quite worn
Help - swingarm chain wear guard thingy?-p1010003.jpg   Help - swingarm chain wear guard thingy?-p1010004.jpg   Help - swingarm chain wear guard thingy?-p1010005.jpg   Help - swingarm chain wear guard thingy?-p1010006.jpg
Old 06-07-2017, 08:54 AM
christok's Avatar
so I think it is called a slider. I made a new one out of some tyvec i had lying around that i used to make the runners on snowmobile sleds I used to make. here are some pics. I will probably try to finds some clear nylon for the future as the white stands out like a sore thumb
Help - swingarm chain wear guard thingy?-p6060003.jpg   Help - swingarm chain wear guard thingy?-p6060004.jpg   Help - swingarm chain wear guard thingy?-p6060005.jpg   Help - swingarm chain wear guard thingy?-p6060006.jpg
Old 06-07-2017, 10:45 AM
Poop's Avatar
Slow=Smooth, Smooth=Fast
i don't have the authoritative answer, but i suspect the same as miami. easy, cheap stuff to get a hand on.
