TP engineering 107
Posted On: 02-21-2020
Posted On: 02-20-2020
Starter torque dpecs
Old 05-29-2017, 05:58 PM
Legend Rider's Avatar
Bike Year, Make, Engine: 07 AIH Legend - 111 Cubic Inch S&S
Engine Popping on De accceleration
Just recently while DE acceleration mainly in 1st thru 4th gear the engine is popping. I have check for air leaks on the carb, found nothing. I'm thinking that one of the circuits on the carb possibly has been messed with since this has happen after the scoot was taken to the shop. Replaced spark plugs, still have the same issues. Engine is 111 S&S with a S&S G carb. Acceleration thru the gears is fantastic, strong, no issues there. Any suggestions?
Legend Rider
Old 05-30-2017, 07:41 AM
Poop's Avatar
Slow=Smooth, Smooth=Fast
what pipes you running? what air cleaner?
also, you can check for air leaks around manifold with wd-40.
Old 05-30-2017, 03:43 PM
I'm running a D&M air cleaner & custom pipes. Like I stated, the problem with the back firing or popping during de acceleration just occurred a few months ago.
Legend Rider
Old 05-31-2017, 02:02 PM
Usually indicative of a lean idle circuit. If this just started and you haven't changed anything...I would check for vacuum leaks...Like Poop mentioned.
Old 07-15-2017, 11:08 AM
Thanks for all the infor. I could not fine a vacuum leak , using WD40. I took the bike to the shop, told the service manager the issue. Let you all know what happens.
Legend Rider
