Posted On: 02-20-2020
Starter torque dpecs
Hunting an AIH Wiring Diagram
Last Post: Bostonjake01
Posted On: 02-15-2020
Old 07-04-2016, 05:48 AM
Shaving decks on Ultima heads
Anyone done this on their Ultima engine? I have the 100ci, giving it a port and polish and I was wondering if decking the heads on these .030" still leave enough valve to piston clearance
Old 07-04-2016, 06:37 AM
magnum45pete's Avatar
Measure it with PLASTIGUAGE.
Old 07-04-2016, 07:17 PM
Cheers Magnum! I'm away from home town for awhile and the heads are getting port mad polished as we speak, was hoping some one might of done head work on these Ultima engines before and could tell me from experience
Old 07-04-2016, 11:07 PM
I would check it first. You can get .030 head gaskets that will do nearly the same thing and with head gaskets if you dont like the results you can easily change them back to .054" which is stock on most Ultima engines.
Old 07-05-2016, 04:35 AM
the thing is every motor is differant even if off the same production line there will be measureable differances,
before doing any kind of skimming on the heads i'd assemble and measure with Plastiguage before any machineing, or ya could end up with 2 paper weights.
as has been said thinner head gaskets will give you an idea of what you will end up with,but even then check valve to piston gap first just in case.
Old 07-05-2016, 06:26 AM
Thanks pushrod and magnum, very helpful information. I'll try the gaskets and measure it
