Owner's manual
Wanted texas chopper risers
Last Post: 1fastlowblow
Posted On: 09-22-2020
Wcc parts and more
Last Post: hansheathen
Old 06-04-2016, 09:03 PM
Chrism28's Avatar
77 shovel trouble starting
Ok here's what I got going on bike ran great I washed it with a power washer like always and went to ride the next day bike wouldn't start was fire a little then backfire really loud so I fucked with it cleaned carbs and all new plugs finally got it to run and was starting and running fine went on a 50 mile ride today and stopped at the bar went to leave bike fired up gave it a slight amount of throttle and it caugh and died with a little poof out the carb but not really a back fire. Got it going and continued on but at all stop signs it wanted to spit and acted like it was running out of fuel but was full had to keep it revved up to stay running got it home it would start and idle then kinda die off and come back barely touch throttle kinda spit and then die now can't get it to fire up turns over but won't start could my coil be bad. The preveous day when I was trying to get it to run it acted like it would load up and gave big back fires out a few times as well I'm lost
2007 custom with 1977 shovel ultima 6 speed trans with open primary
Old 06-05-2016, 08:56 AM
magnum45pete's Avatar
what carb ya using???... if its an S&S or a std fit Bendix I'd junk it for either a Mikuni or a Harley CV carb...they both are easy to fit /tune & start real easy, also give good performance and economy.... plenty good used CV's on ebay for 50 or so.....
Old 06-05-2016, 09:13 AM
Chrism28's Avatar
It is a s and s carb I've had really good luck with it and bike ran real good till I washed it and that's were it all started after I did get it running I only road on a short ride
Old 06-05-2016, 04:23 PM
Sounds more to me like wet ignition parts somewhere..You say you washed it and it started doing this? I would spray the coil and wires down with wd 40 to displace any water, and check carefully for any hairline cracks in the coil...this sounds classic....electrical.. not carb..
