Last Post: CIC2016
cfl single downtube chopper
Posted On: 01-15-2020
Vertical stretch
Last Post: riverratba
Old 07-09-2015, 06:39 AM
christok's Avatar
Bike Year, Make, Engine: 2009, saxon custom,S&S
chain tensioner help
I have some questions with respect to chain tensioners. Monstercraftsmen makes some nice chain tensioners using skate board wheels which can easily be replaced when worn out. I have sent them 2 emails with my questions but still have not heard back from them which is a little concerning right off the bat. here are my questions
1) all their videos show the chain tensioner mounted on a hardtail frame. can I use a chain tensioner on a swingarm frame ? I have converted one of my bikes to a 5 inch extended swingarm and went to a chain drive to fit my 330 on the rear
2) all the videos I have seen show the tensioner mounted below the chain pushing up from the bottom - can the tensioner be mounted above the chain pushing down on the top?
any input would be greatly appreciated thanks
Mold your dreams into reality
Old 07-09-2015, 09:13 AM
Poop's Avatar
Slow=Smooth, Smooth=Fast
the top side of the chain is the part under load when you accelerate. typically, sprung chain tensioners are meant to work on the bottom side, where there is typically more slack, less tension.
Old 07-09-2015, 10:21 AM
Originally Posted by poop View Post
the top side of the chain is the part under load when you accelerate. Typically, sprung chain tensioners are meant to work on the bottom side, where there is typically more slack, less tension.
i think he means to pick up slack of the bottom strand of the chain but from inside of the loop, not outside.
I have seen that done[ seems less common though- one can google chain tensioners images on the web]
ii have used chain tensioner from monster craftsman on my swing armed / suspended chopper, but i din't like the small 13 teeth sprocket adding extra noise.[later i used it on my open primary, but eventually eliminated it as well]
perhaps the rubber roller mc sells[ i would prefer the sturdier version of the two, not the skateboard's] ] would be quieter.
Actually, i think due to the nature of suspended bikes - chain alternates between relatively loose and tight with the suspension work- i would think chain tensioner wold be a good idea.
The only reason i would use chain tensioner on a rigid bike- if the chain was too long and had to travel bypassing some obsticles
Old 07-09-2015, 01:28 PM
christok's Avatar
thanks guys that answers my questions. now if only i can get in contact with monsterctraftsmen . I want to go with one of the rubber versions to avoid the additional sprocket but not sure which one yet. if i go with the Powell skate board wheel i can get replacements easily and locally whereas the other one made by craftsmen would be available only through them so in case of an emergency i can get the other wheel here at a skateboard shop or sporting goods store.
Old 07-09-2015, 06:39 PM
Then try the skateboard one , you always can buy their roller upgrade ( they sell it separately) - the arm, mount and spring are the same I believe( check the axle , shoulder bolt size, 1/2"?)
Cheers
