TP engineering 107
Posted On: 02-21-2020
Posted On: 02-20-2020
Starter torque dpecs
Old 07-05-2015, 12:00 PM
Bike Year, Make, Engine: 2007 ULTIMA / 1999 HARLEY
Exhaust too close to timing cover/area
I had a custom exhaust built to my design. I am wondering if it is too close to my timing area of the engine.(PIC enclosed) I am conserned about the heat generated from it. I currently have the pipe wrap off and am going to have exhaust sandblasted, powdercoated, then re-wrapped. i noticed when riding it without the wrap that the heat was VERY extreme compared to when i rode it without the wrap. Even with the wrap , do you think the pipe is too close to the timing cover area? any comment or suggestions would gladly be excepted.
Exhaust too close to timing cover/area-aftertroy.jpg
Old 07-05-2015, 12:33 PM
ecir45's Avatar
heat rises I would say you're OK
113" El Bruto / 5 speed
Old 07-05-2015, 12:49 PM
magnum45pete's Avatar
ya ok i'd say...not like it's touching the cover.... points will be fine ..if ya use an electronic ignition modual it might not like heat but it looks like its clear by a decent amount
Old 07-05-2015, 01:31 PM
I dont think your pipes are any closer than any other EVO powered scooter. Although heat is the enemy of any in cone ignition module I think you will be ok. If you do kill the ignition module you could go to a remote module ignition. I used a remote module ignition on my hotrod FXR. It just used a pickup in the cone and the module is under the seat. Its been in the bike since new in 1999, Knock on wood, with no troubles at all.
Old 07-05-2015, 01:35 PM
ecir45's Avatar
Originally Posted by pushrod243 View Post
hotrod FXR
Hoping my next bike to be a FXR, do you have any pics.
Old 07-05-2015, 01:50 PM
Its a older build. Kenny Boyce frame Scooters built 113 with STD cases and STD heads. It was the first 4" bore STD cases. Zippers cam it has gobs or torque I cant help but smile when i twist the throttle..If i were to do one again it would look more like the ones Gypsy was building but with a big inch twin cam engine.....
Old 07-05-2015, 01:59 PM
ecir45's Avatar
Thanks for the pic, the seat rear fender on that one flows the best from pics I have saved. Sorry about the off topic JokerRides
