2004 Bourget Retro
Last Post: DRZ
Posted On: 08-11-2020
Last Post: logan
Posted On: 08-09-2020
New Forum Member
Old 05-24-2015, 06:51 PM
Merlin Hawaii's Avatar
DON'T WORRY - BE HAPPY
nevermind
"Hula Baby"
Old 05-25-2015, 01:43 PM
joebudd's Avatar
Bike Year, Make, Engine: 2007 Big Bear Chopper DA prostreet
Ok. Today I pulled the drain plug on the crank case. Maybe a half ounce of oil dripped out. Then I hooked a clear hose to where the crank case breather was hooked to. Started the bike and a little cream came out. So the must be little moisture in there. How can I clean all the moisture/water out of there?
Old 05-25-2015, 02:23 PM
Run the bike and the water will evaporate
But you have to ask yourself, How did water get in there?
And the only way water can get in there is through the breather vent
And the only way water can get in through the breather vent is if you have a filter on the breather hose, and the filter is higher than the vent port on the case
"Hula Baby"
Old 05-25-2015, 03:33 PM
Water can get into a crankcase just by sitting in a garage in a humid climate.....it forms when temperature changes.....a crankcase is not sealed up......That is why it is recommended to drain oil when ever the bike is going to sit up...it can also create sludge in the bottom of the crankcase and create all kind of problems.....I have found my lawn mower gas tank with 80% water in it at the beginning of the season.....a little moisture should clear up......make sure that's all it is...
Old 05-27-2015, 06:00 PM
joebudd's Avatar
Looks like I am going to install a Engine Breather Oil Collector. It will hold the oil and then you can drain it.
Old 07-14-2015, 11:24 AM
joebudd's Avatar
Ok. Installed the collector. Made it about 40 miles and had some oil coming out of the collector breather filter. So my question is, If the pressure is increased on the cylinder head breathers that send the air/oil back to the intake, do to fixing the air leaks. Will the pressure in the crankcase?
