TP engineering 107
Posted On: 02-21-2020
Posted On: 02-20-2020
Starter torque dpecs
Old 05-23-2015, 01:52 PM
Bike Year, Make, Engine: 05 american iron horse legend
Oil issue.
111" S&S.Went for the first ride this year.Got home and took the oil cap off the tank and oil started coming out of the top?Put cap back on.Any ideas why this would happen.Pretty sure it wasn't over filled...Thanks Dave.
Old 05-23-2015, 06:59 PM
Are your cases vented.?. maybe your head breather is unhappy or getting stopped up..or your umbrella valves need cleaning I would vent the cases and see if it relieves the problem.. you don't want pressure in there ..it does all kinds of weird thing to an engine.. if you went for a first ride is there a possibility of sludge from sitting? why don't you pull your case oil drain plug and look at your oil for sludge..there is only a few ounces in there..
Old 05-24-2015, 03:44 AM
Merlin Hawaii's Avatar
DON'T WORRY - BE HAPPY
Are you sure you didn't overfill it?
You have a dry sump oiling system, so you have to put in NO MORE oil than than your oil tank manufacturer recommends - (usually around 3 qts in a horseshoe tank - less in a custom tank)
If you filled your oil tank to the top when the bike was cold - then you put in too much.
So after the bikes at normal operating temp, that excess oil's gonna come out through the breathers and the filler bung when you take the cap off.
"Hula Baby"
