Hard Core II builders
Last Post: Fatback
Help identifying 70's - 80's springer
Last Post: tnbkrtrash
Posted On: 10-21-2018
Wtb: Primo open belt drive
Last Post: rkduq20
Posted On: 10-19-2018
13 Ignition Dropping Out
Last Post: BostonShovel
Posted On: 10-17-2018
Old 05-01-2015, 08:34 AM
Oldschoolpaulie's Avatar
Pop-up gas cap dilemma
When we were putting my bike together years ago, I made the mistake of buying a gas cap on ebay. It was a weld-in pop-up version, surely for a standard Harley size, but the tank/cap went on my metric. The problem that has arisen since last summer, is that it will begin to seep gas out on the low side, letting it run down my high-dollar paint. The only way I've found to avoid this, is to unscrew the cap when I park it for the day, and just set it in the recess to keep out contaminants, without screwing it in. I also pull it off and put it back on whenever I stop for lunch or something while out riding- but even this practice often results in the leaking of fuel when I'm out riding, especially on hot days.
The cap is vented, as I can blow out air through it from the bottom. I figured it was the gasket, so I searched pop-up gas caps on the net, and though the ones from Pro One looked like what I had, so I got a new gasket from them... the problem was that, while the gasket went on the cap fine, when I tried to put it in the tank, it was just barely a few thousandths too big in diameter.
I emailed a photo of the cap to Pro One, and they said it wasn't theirs. They recommended checking with Pat Hotch, so I emailed the photos to him. He, too, said it wasn't his, and when I asked if he had any ideas who might have made it, he said he had no idea- and added that, during the bike boom, companies sprung up all over making knock-offs, and ultimately went out of business after the 2009 crash.
I sent the pics to Custom Chrome, and it isn't theirs, either.
Next, I hit the hardware stores and plumbing supplies. My brother, a foreman at a water treatment plant, said he had a large assortment of gaskets and O-rings at work we could sift through- no luck there. I even contacted a company that custom-makes gaskets to order, measured it with my dial caliper, and got an estimate- $290 for 50 gaskets- the minimum number they can cost effectively make. (Not very cost-effective for me)
Today, I'll be out riding, and plan to take the cap into my local Freedom Cycle outlet- they're well-known for making an effort to drag out what they have to see if it works with your application.
If I strike out there, I'm out of ideas.
Hopefully, there's someone here who knows gas caps and might have a good suggestion.
Old 05-01-2015, 09:23 AM
flysocal77's Avatar
Post a pic and dimensions. I got a couple hundred o rings and would be happy to send one to you. Im not understanding why such a hard time finding the correct oring, they are rubber so you just need to stretch something that's close.
Old 05-01-2015, 02:22 PM
I'll get a pic posted after I get home. Actually, it is more of a flat washer style gasket, black rubber. Here are the dimensions:
1.664x1.274x.122
Actually, my brother gave me an O-ring that we stretched a bit, like you said, and so far, today, ( I've been riding all day ) it hasnt seeped out onto the tank like it was- but im afraid it's because it just venting the gases better, and it will run out if i fill it up all the way.
One bone head stunt I did when he built mine, was putting the gas cap on the low side to be "different" – should have been on the high side. I cant fill it as high, and that fat bastard only holds like 2.8 gallons.
I appreciate your offer to help, and as I said, I will get some pics up tonight.
Old 05-01-2015, 08:19 PM
Some pics:
Pop-up gas cap dilemma-img_4765.jpg   Pop-up gas cap dilemma-img_4974.jpg   Pop-up gas cap dilemma-img_4975.jpg
Old 05-01-2015, 08:35 PM
And the original gasket.
Old 05-01-2015, 10:29 PM
Same as mine, and mine does the same thing..but only sloshes out while riding if you over fill...hope we can find something...
Old 05-01-2015, 11:17 PM
Hell, worse than that... mine started sputtering one day while I was riding and died. It would start, run a few seconds, and die. Drained the tank and found water in it... then i realized I'd washed it the day before... it leak IN as well as OUT.
Old 05-02-2015, 04:51 AM
Bike Year, Make, Engine: 1998 home built,113 s&s
i have the same cap.if you guys know how to keep them from rattling when you ride,can you please let me know?
Old 05-02-2015, 08:16 AM
Rattling??..not sure how one could rattle if it is screwed in with threads.........EDIT...I just went out and looked at mine and I do see how it could rattle..however mine does not because it locks tightly....
and I think the reason I don't get the gas seeping out when the bike sits is because of my home made gas gauge.
I have a piece of clear hose running under the tank and up to see the gas level and the valve on the end is letting the pressure out....mine has an o ring gasket...
Old 05-02-2015, 08:37 AM
If mine is rattling, I'll never hear it over the motor…
Old 05-02-2015, 02:45 PM
I fixed mine by machining an "o" ring groove in the cap. Choose the right size rubber o-ring to suit.
It doesn't rattle and it doesn't leak.
Old 05-02-2015, 04:46 PM
I played with mine all day today..and fixed the problem..turns out that I have a pressure problem and not a gasket problem...I cleaned a bunch of crud (ethenol) off of the tank seal and now my cap seals ..but I have a new problem that hit me when I filled up today,,,now if I fill it it on the stand and put the cap on, it blows up through the vent all over the place when I stand the bike up... I ran a hose off of my home made gas gauge as described above and ran it down and under the bike to the back(away from the exhaust) and now if it wants to squirt... it can squirt out onto the ground...at least it's not on my tank....one other thing that I found is if I tighten my cap down until it barely touches the o ring it allows the pressure to escape but is tight enough so that it doesn't slosh out. now I can fill it to the top.
Old 05-02-2015, 04:59 PM
By the way, that is an excellent idea Jedi...wonder if it would hold back pressure?
Old 05-02-2015, 08:47 PM
That's one problem we don't have in Oklahoma… With five refineries in our state, we can always find 100% gas.
Old 05-03-2015, 11:22 AM
great idea about the o-ring groove,thanks.
