Last Post: chopperfugger
Last Post: cntrhub
Seen the new Harleys?
What are these?
Last Post: erlobulldog
Posted On: 03-30-2020
Last Post: CIC2016
Posted On: 03-29-2020
Old 04-28-2015, 10:43 AM
Mikuni HSR42
Hi guys, I really hope you will be able to help, I'm building a old school bobber over here the UK, and im using a Revtech 100ci engine with a Mikuni HSR42 carb, can anyone advise me as to what aftermarket filter I can use, as I can't seem to find anything online.
Thanks in advance
Michael
Old 04-28-2015, 12:45 PM
magnum45pete's Avatar
go on ebay,...lots of filters for them when you use the adaptor that is for sale there.
( Mikuni HSR 42 45 Aircleaner Air Filter Adapter for Harley Davidson | eBay ).....
Dennis Goodson (USA) also makes a VERY classy range of hand made polished aluminium air cleaners.....or make a filter fit...it is a ''Custom'' bike after all....
Old 04-29-2015, 07:25 AM
Welcome to CC! Yup, that adapter will allow you to fit a wide variety of air cleaners. Here's my teardrop...
Old 04-29-2015, 07:01 PM
The revtech uses a flange style manifold with a spigot adapter it sticks the carb out about 11/16" further than a standard v-twin setup. If you run a air cleaner with an exposed breather its just as simple as putting the carb support on the outside of the head breather banjo and you have fixed the spacing issue. If you try to install a air cleaner with an internal breather you will need to add a spacer and in most cases longer breather bolts to get everything to bolt up.
Either way you will need one of the adapters linked above. I have them in natural finish and Chrome.
Mikuni to CV air cleaner adaptor [86086] - $19.99 : Scooter's Performance
If you find something you like that has an internal breather I can help you source spacers and longer breather bolts
