Substituting an 16" rear wheel for a 18" question
Last Post: erlobulldog
Last Post: chopperfugger
Posted On: 04-05-2020
Pushrod u still on here?
Last Post: fifty
Posted On: 04-04-2020
Posted On: 04-03-2020
Old 04-08-2015, 05:38 PM
on_the_fly's Avatar
Bike Year, Make, Engine: 2001 Honda Aero 1100cc
79 ironhead primary question
Ok I started getting loud noise in my primary, got bike back to house n on lift, found that the clutch cable arm that pushes clutch in is tapping the six clutch basket bolts, (the part of the assembly that guards n keeps clutch cable away from clutch basket,
How,why is this possible n how what need to fix, a point in right direction be great,
Thanks guys
Old 04-08-2015, 06:01 PM
on_the_fly's Avatar
Here is where it's hitting, ya can see the shiny part over cable
Old 04-08-2015, 06:04 PM
on_the_fly's Avatar
Ok I'm posting from my phone so hot to blow it up to tell but can see the six clutch basket studs it's hitting
Old 04-08-2015, 08:40 PM
Can't really tell from the pic what's hitting but the cable looks to be on the wrong side of the release lever.
Old 04-09-2015, 10:07 PM
Chain is too loose. Look for that wear spot on the throw and push it back. Look at the spots it looks like it's hitting... at the plate, not the bolts are being torn up, right? Primary looks dry.
Old 04-10-2015, 05:35 AM
on_the_fly's Avatar
Took primary cover off night before took the pics, had plenty of revtec primary oil in it, I do think my chain n tentioner block are both shot. But that wouldn't cause the the clutch cable lever to hit the clutch basket studs would it, is it possible that the clutch disc are shot n clutch and between clutch pushing out and maybe cable arm adjusted for that put it in to Farr and by time add the two together they touch now ? I realy don't see what's going on, I'm at point I think I'm gonna hunt down new clutch plates, chain, tentioner block, and cable case arm and just put it all in new .
Still would like to know why it's hitting, I figured surely someone on here knee or had same issue before .
Old 04-10-2015, 11:15 AM
The chain has slack in it because the adjuster on a Sportster is in the cover, like I said I can't see the studs so I can't be sure if they're rubbing but I am sure that your cable is digging a groove in the gusset on the primary cover which makes me think that something isn't correct there(I had a '77 with the same setup but it's been too long since I had a close look at it). On that setup the studs(which are attached to the bottom plate) will move outward with clutch fiber and steel wear so looking inside of the basket isn't a bad idea. Is the noise constant or does it go away with the clutch in when you are in gear and sitting still?
Old 04-15-2015, 05:04 PM
on_the_fly's Avatar
Still haven't pulled back apart yet, figured I'm gonna go ahead n put new primary chain, chain tensioner, clutch plates n new clutch release lever kit. Try to tear it down once
Old 04-19-2015, 12:46 PM
on_the_fly's Avatar
That's not a groove cut , it's just the casting of primary cover
Old 04-19-2015, 12:49 PM
on_the_fly's Avatar
Here is where it's hitting the clutch basket
Old 04-19-2015, 12:52 PM
on_the_fly's Avatar
Here is still on bike , can see hit the tips of all six
Old 04-19-2015, 12:54 PM
on_the_fly's Avatar
This is the clutch release lever that's hitting them
Old 04-20-2015, 06:26 AM
Good pics, that helps...however... nothing stands out like it would be the problem. Check your hub nut and make sure that the hub it tight on the shaft, make sure your basket bearing is good, generally make sure that the basket can't be moved in and out, and check your throwout bearing. Did this start all of a sudden, and when it did what was your clutch adjustment like before and after the noise started?
Old 04-20-2015, 05:01 PM
on_the_fly's Avatar
I think I found the issue, the clutch basket bearing is wearing. I had side to side play but not in n out. I think a combination of the play with the bearing and the were in the release lever. So I'm putting new bearing, clutch disc, primary chain,tensioner block, n release lever. Got half parts ordered n have going rest just gotta come up with the rest of the cash lol
