10-30-2014, 05:15 PM
qc
auto clutch EFM
hi all
just got my auto clutch.. gonna install on my ultima open belt...3.inch
i gotta remove the six center studs.. i dont remember if i need to pull out the basket or can i get them without removing it?
thanks
10-31-2014, 02:21 AM
NJ
Originally Posted by wannabuild
hi all
thanks
You,re good. I don,t think anything interferes with unscrewing them right there.
Remember, you need an approximately 2.5" long a pencil thick spring installed around the end of the cable ( inside the right side trany cover) which pushes the ramp back to resting place. The inner diameter of the spring is just big Enough to slide over the cable end.
10-31-2014, 05:43 AM
US
What if you have a hydraulic clutch?
I just looked it up. It works with hydraulic too.
10-31-2014, 07:11 AM
NJ
Originally Posted by rhode warrior
what if you have a hydraulic clutch?
good point, i never had it, but i would think something should return the lever back into the resting position at least for cosmetic reasons.
Come to think of it, may be it's not necessary- while the engine is running, the pressure plate does that with ^ rpm. But i don't like to have it in comressed position or loose with engine off. I guess not a big deal.
10-31-2014, 07:18 AM
US
Rekluse auto clutches have been used on dirt bikes with hydraulic actuators for years.
10-31-2014, 09:14 AM
NJ
'I just looked it up. It works with hydraulic too.'
I didn't say it hadn't. Just assumed he was using cable..
10-31-2014, 09:18 AM
US
I was looking it up just so I would know and sharing the info.
10-31-2014, 09:23 AM
US
I still don't know how the clutch lever reacts though. Guess I'll find out. I plan to use one on my prostreet bike.
10-31-2014, 10:10 AM
NJ
to use efm?
10-31-2014, 02:41 PM
US
to use efm?
Yes EFM Autoclutch
10-31-2014, 02:42 PM
US
I called EFM a little while ago. He said it works the same just a little different adjustment with the hydraulic actuator.
10-31-2014, 02:46 PM
qc
yup studs came right off ..
all installed and hooks up nice.. my only issue is i have absolutely no clutch play im out all the way on my cable adjustment and there is atleast another 3 inches of cable..
i can shift through the gears without clutch when close to idle but not so smooth when driving at speed..
any thoughts?
thanks
10-31-2014, 03:19 PM
NJ
any thoughts?
thanks
Correct clutch cable?
And the other thing, remember there,s nothing pushing the pushroad and ramp back to tighten the clutch cable...till the engine is on. May be that,s why the cable looks long...the ramp is mot in the place.
10-31-2014, 04:01 PM
qc
nah
cable is good.. was on before installing the efm unit.. i will try reajusting the bloddy thing..u got a pic of that spring u used?
thanks
10-31-2014, 04:47 PM
NJ
nah
thanks
Then it,s definitely the case of the ramp being in the engaged position thus the cable is all the way out.
I have an old actuator, so I took a picture of it with the spring with a skewer pretending to be a cable.
The spring is 2.5" long with ID 5/16- just to slide over the cable,s head. Don,t recall wire thickness, but somewhere around 1/16". Grounded ends. Bought at mcmaster
It will return the ramp to resting place
That,s how I did it on 3 bikes.
