TP engineering 107
Posted On: 02-21-2020
Posted On: 02-20-2020
Starter torque dpecs
Old 09-25-2014, 06:25 AM
Bike Year, Make, Engine: 2003, AIH Texas Chopper, S&S107
2003 Ironhorse Primary
Hey all, I'm new here and was wondering if anyone could help me out?
I've owned my '03 AIH Texas Chopper for a few years and I've decided I want to run a 3" open belt drive primary. Preferably a BDL as I've been given a custom cover plate that suits them.
Either the EVO-9S - EVO-9S
or the EVO-9SF with the oil filer - EVO-9SF
These are the drives that the cover plate bolt pattern will fit. The only thing I'm unsure of is which one of these, if any will suit my bike as I have no idea what primary mine is running. It's a softail with a 1 7/16 offest.
Any help would be appreciated.
Cheers
Old 09-28-2014, 02:44 PM
rootercycles's Avatar
Bike Year, Make, Engine: Homebuilt 127
Either one will work. Not a fan of the oil filter in the primary, but to each his own. Look for a used one and save some $. They polish up nice and parts are easy to fine
Old 09-29-2014, 08:59 PM
You need measure your outer cover the older BDL's have a different bot pattern than the new ones have. Covington & joker used to offer adapters but neither sell the covers or adapters any longer.
Steve Dameron might be able to make you an adapter if your cover doesnt for the new drive.
Both drives should fit your Ironhorse with the proper offset spacers.
Old 10-02-2014, 10:38 PM
Many thanks for the help guys, much appreciated
Good to know both will work, as I'm not a big fan of the oil filters in them either.
Adapters/plates etc are also not a problem as I have a custom bike builder here in Aus that will sort all of that out for me.
Thanks again
Old 05-15-2015, 11:28 PM
Hay there just wondering if you have any contacts that i mite get my hands on some 03"- 04" texas chopper risers , thanks.
Old 05-16-2015, 05:41 PM
Skydiver's Avatar
Bike Year, Make, Engine: American Ironhorse, 2003, S&S 107
I have an 03 Texas Chopper that I installed an Ultima Drag style open belt drive on that I am extremely happy with. The offset for your bike is 1 7/16" but no one makes that off set. Use the 1.5" offset and loosen your transmission to frame bolts when you install the back plate and it will match up fine. Here is the install I did on mine a few years ago.
http://v2-forum.com/forums/showthrea...ght=belt+drive
Old 05-16-2015, 05:44 PM
Skydiver's Avatar
Oops, just saw that this is an old thread. Hope it all worked out for ya.
