Rear wheel question
GURU's GARAGE
Last Post: Guru Romania
Posted On: 01-21-2018
Big Dog fwd controls NEW
Posted On: 01-17-2018
Old 10-05-2004, 10:13 AM
Bike Year, Make, Engine: Custom Shovelhead Barhopper, BBC Venom
BDL -Noisy Clutch!!! Why
Why are the Clutches on BDL drives so noisy when they are disengaged?
I'm putting one in my Venom and would to fix it before I finish the bike.
If there is a way to quiet them ???
Old 10-05-2004, 10:37 AM
superjet's Avatar
Bike Year, Make, Engine: 2004 Hardcore II, 98 FLHTPI, CFL Started
Send a message via Yahoo to superjet
It is the way dry clutches are. Go check out a stock Ducatti. They have the same rattle.
Embrace the rattle.
Respect is not a sign of weakness.
Old 10-05-2004, 10:47 AM
I would rather "erase" the rattle.
I've got a Barnett clutch on my old Shovelhead.
It's dry with a belt drive and it's a lot quieter.
Although it does make other cement mixer noises, but that's another story...
Old 10-05-2004, 11:22 AM
Bike Year, Make, Engine: many
well we all realize that running an open belt drive primary (assumming thats what ur talkin about), that the clutch basket is no longer encased in the outer primary cover which subdued alot of noise............i just assembled bdl's new "quiet clutch pack (for prior mentioned complaints), it came assembled but that didnt fly, i had to see what was "quiet" about them. the friction plates are pretty much the same as all others, the steel plates are designed slightly different but the biggest change i saw was the design of the pressure plate. it is suppose to control the steels better on disengagement so its not so noisy. i havnt been able to run it yet(prob this weekend) to see how much a change there is, i'll let ya know.
also a noisy clutch is sometimes an indicator of a bad spring plate. within the clutch basket among the steel plates (usually in the middle of the pack), is a different looking steel plate. looks like 2 steel plates riveted together. if that plate has any movement at all between the 2 it is bad and must be replaced. also replace the other steels when replacing the spring plate.
hope this helps,,,,,,,,,,,,,,,,,,,,chad aa/mc's
aa/mc's
Old 10-05-2004, 10:19 PM
bigazzgunz's Avatar
Retired Super Mod
Bike Year, Make, Engine: Diamond Chassis, Accurate Eng. Pan
Send a message via AIM to bigazzgunz Send a message via Yahoo to bigazzgunz
Good info. Keep us posted. I'd like to hear more about the quiet clutch pack!
Old 10-06-2004, 12:22 AM
kirkscustoms's Avatar
CC Member/Builder
Bike Year, Make, Engine: 03' & "05 Kirks Customs Rigids, '76 XLCH
I have built 2 chops using BDL's, they both have had the quite clutch pack, it is quieter than most but still makes noise, Live with it! for my money a BDL beltdrive is the only way to go, 1/3 the price of a primo, bout the same as a regular primary, less parts than a regular primary, better hookup, easier to work on, ever had to pull a standard primary and put it back together, oil, mess, about 4 hours, who needs it. It is a dry clutch, also behind your clutch pack is what is now your compensating sprocket, know how an impact wrench works? well that's what it is! that's what is making all that racket. As your friction plates wear it will increase in noise a bit cause it has more slack, if you run all 9 springs like I do, it helps not only with noise but doesn't wear out your plates as fast cause they ain't slippin. Plus, it's just plain cool!
Old 10-06-2004, 10:15 AM
Thanks for the input.
With my Shovel, each steel plate has small spring loaded balls that bear against the basket rib, taking up all the lash.
I was wondering if that (plate rattle) was the same reason for the noise and if there were any known fixes.
Clutch is brand new, so I doubt the spring plates have come apart, However I will check...
Old 10-06-2004, 11:01 AM
Bike Year, Make, Engine: 08 R.T. Dyna Fat Ass Chopper,
My clutch doesn't make a rattle its more of a knock. With the motor stopped if I grab the spring plate and just rock it back and forth, that is the noise that it makes at idle. It is the plates hitting the pins. I have replaced the original clutch pack that came with the kit with their" new" clutch and there is no difference in the two as far as that knocking sound . Other BDL's that I have heard all have that traditional open belt sound, I have decided to just live with it because nobody seems to be able to help me out. Thunder
Old 10-06-2004, 11:40 AM
CC Member/Builder
Your clutch pack and drum is one geat big hammer, it takes too long to explain. You no longer have a compensating sprocket as part of your motor pulley. It is part of your clutch hub now, that means for every revolution of the motor the clutch hub only makes part of a revolution because it is not a direct lockup on the trans shaft . A V-twin motor has a natural stutter, miss, if you had a clucth hub directly locked up to the motor you would have direct drive, this hub freewheels inside to let the motor do its thing at idle, if it didn't shit would break!, that knock is being created because the unit is doing exactlay what it is supposed to be doing acting like an impact wrench!!!!!!! live with it! or change it to the mess of a closed primary.
