Turn signals
Last Post: gduncan
Posted On: 07-09-2020
Posted On: 07-08-2020
Identify Frame *Help
Last Post: gduncan
Posted On: 07-06-2020
Old 07-01-2017, 04:02 AM
Originally Posted by Webby View Post
Did you have any luck? I have a 87 heritage softail I was thinking of ptting on a 5degree rake, with a 21" skinny
Do yourself a favor,
Check with this calculator the setup you have , putting different desirable rakes in the tree: 3*,5*,7*. I have seen 10* raked trees + adjustable angle( Tolle) trees.
https://www.rbracing-rsr.com/rakeandtrail.html
Then double check mocking up your bike while angling fork ( or broom stick)forward till you have the correct trail and using angle measuring device. Subtract the stock neck rake from the total angle on the devise and you have the desirable tree rake. Chose the closest available raked tree.
In general, the more rake in the neck, the more tree rake will be required to normalize the trail to 2-4".
Rarely people use more than 7* tree. I don't think on a stock bike you should use more than 5*. Thank god stock Harley rakes are in general more than 5", so they can be reduced. They don,t care much about slow turning, but don,t want to be liable for the high speed wobble.
My chopper has neck 49* and 7* tree, with trail slightly above 4". Very nice handling even with tiny handlebars.
