Go Back   Club Chopper Forums > GENERAL CHOPPER TALK AREA > Chopper Builder's Log > Rolling Thunder Builds
Last Post: chopperfugger
Last Post: juanba
Posted On: 05-27-2020
Rear wheel spacer
Posted On: 05-26-2020
Posted On: 05-25-2020
Pushrod adjust.
Old 08-11-2010, 10:14 AM
seatux's Avatar
Location: SW Ontario, Canada, but wish i was back in, BC
Rolling Thunder 6up 10 out 48 deg rake build
Thanks to Mr Scary for adding this sub forum.
I will start adding pics and info of my slow build this evening
Old 08-12-2010, 07:10 AM
seatux's Avatar
Thumbs up Some pics of the frame, wheels and tank
Yes it is a piece of wood....... trying to take some measurements for springer options.
Figure it is going to be 10ft long minimum.
Old 08-12-2010, 07:15 AM
hspring03's Avatar
Slick looking frame
Countdown
Old 08-12-2010, 11:08 AM
nanaimoBC's Avatar
Bike Year, Make, Engine: 2007 nemesis 250R
that is long....ya nice frame
Old 08-12-2010, 11:23 AM
8up8down38's Avatar
Bike Year, Make, Engine: 2007 Street Glide Bagger
Nice single fork.... Looks like it's going to be a killer sled!!! Keep those pictures coming...
Old 08-12-2010, 12:20 PM
Welcome to radical rakes!!!
Originally Posted by seatux View Post
yes it is a piece of wood....... Trying to take some measurements for springer options.
figure it is going to be 10ft long minimum.
try to use a few different rake/trail calculators - some online, some downloadable to get a ball park of the length you need.
Don't level you bike perfectly to the floor with fully extended fork. Keep front of the frame .5-1'' higher than back, then chose the fork length: When the bike loads up with all it's weight- it will collapse the fork a bit( for hydraulic fork it's typically 1-1.25''. Not so sure for springer- but still some.)- that might come close to the level.
Remember- you also will be sitting on the bike[another 200lb?]- so with you on it - it still should look level or slightly higher in the front, but not lower!.
I'd rather see a bit longer front than too short. I whink you can shorten either hydraulic or springer manipulating with it's components.
Good luck
Old 08-12-2010, 01:58 PM
That thing is gonna be cool its a long Mfr looks great
Old 10-13-2010, 05:11 PM
olddude13's Avatar
Bike Year, Make, Engine: rolling thunder frame ultima 127''
Nice start !! Sam at rollingthunder can help with the details for your forks. They make a nice springer .
Old 02-14-2011, 06:07 AM
seatux's Avatar
Question Help identifying this headlight so I can buy one.
I tried contacted the guy but no luck.
Any help, identifying this headlight would be appreciated, as I want one one for my build.
http://www.veteranvoice.info/bulletinboard.htm
Old 02-14-2011, 06:35 AM
looks like maybe a headwind...or some copy of that....
Old 02-14-2011, 06:39 AM
seatux's Avatar
Any idea what size it might be?
Old 02-14-2011, 07:17 AM
looks like a 5 3/4. Headwinds call it a Bradley Bullet. There are copies as well. I have a copy I can sell much cheaper
Old 08-29-2015, 07:15 AM
got any specs on the frame,trees ?
Tags
48 deg rake, 6up 10out, long bike, stretched
